-2001 Nissan Gloria Ultima 87xxx kms
-VQ30DET (single turbo)
-4 speed auto (no CVT)
-Serviced 2000km ago
-Grey interior with woodgrain trim professionally vinyl wrapped charcoal grey
-Rear privacy glass - quite dark
-Dual-zone climate control - front/left+right can be set to different temps
-TV/Navigation - not converted to aus
-Driver + passenger airbags
-Electric seats
-Electric mirrors
-Electric windows
-Self closing boot
-Power steering
-ABS
-Remote key-less entry with central locking
-Smooth quiet drive, good power, reliable
-Car has a few mods as follows:
-Jap Wheels, Blest Bahnsport Type D in 18x8+38 front and 18x9+35 rear.
-Brand New Achilles ATR Sports front and rear.
-BC Racing BR series Coilovers front and rear
-Custom 3" stainless front pipe with deleted cat
-Fujitsubo 3" stainless cat back exhaust with twin tips, Legalis R series so under legal noise limit
-Custom front mount intercooler set up
-New Alco battery
-6000k low beam HID kit
-All interior globes included cluster changed to white LED
-Nardi Steering wheel NOT included in sale, will have the standard wheel put back on.
-All standard parts will be provided with car.
-It has an integrated screen in the dash for all in car display and comes with a translation guide as it is all in japanese, still very easy to use took me only a couple of days to get the hang of what all the buttons do. Car was imported in 2009 and i am the 2nd registered owner, it came to NSW from SA and to the best of my knowledge it is the only one in NSW, i have all the original import paper work and also all of the factory user manuals that came with the car. Body is in good nick few scratches but not too bad for a daily drive.
More Photos on request.
Price $13,000
Sam. 0432 228 214
861435_10151496957376211_993895610_o_zps
  • Like 1
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
Thanks mate, not sure who the original importer was off the top of my head would have to check the paperwork I have.
All the wiring is intact, it now has the factory steering wheel back on it.
  • 3 weeks later...
shame theres not much demand for these cars. mainly because auto.
Great cars though and little demand means very unique and uncommon :)
glws
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
