alright quick rundown of whats going on here on my 260RS stagea
1- as i pull up and my RPM drops it will dip to 600- 700 rpm for just a fraction of a second, as it does that the oil pressure gauge will shoot straight to zero for a few seconds then slowly rise back up
2- it will only do this on a hot engine, doesnt happen at all untill the car is up to temp
3- oil pressure light on dash also lights up (is there a separate sensor for the light and gauge?)
4- oil level is fine and ive checked for leaks, none
5- pressure will also drop if engine is warm and im sitting on the spot, rev it up to say 4000+ rpm and again on that drop to 600-700 rpm the oil pressure gauge will intantly drop to zero then slowly rise back up
any ideas guys??
cheers =]
https://www.sau.com.au/forums/topic/444506-oil-pressure-dropping-rb26/
The factory gauges are notoriously bad.
The fact your light come son in concerning as it's separate to the the gauge.
What grade oil are you running?
I would get something thicker in there asap and start planning pulling the engine out.
Ohhh right so they actually are off the same sender?...well in a way that's good news
Hopefully that's all the issue is.... ill pop into nissan and grab a sender tomorrow
probably worth fitting an aftermarket gauge to keep an eye on things for future too if they're really that bad
http://www.kudosmotorsports.com/catalog/genuine-nissan-oil-pressure-senser-genuine-nissan-nissan-300zx-z32-skyline-r31-jdm-r32-all-r33-all-r34-all-p-1220.html
This ^ is a very good price. I bought one recently which resolved a similar issue on a 32 4 door.
Normally $200+. God knows what Nissan will charge, so please post back their price too.
Alright quick update
Thanks for the link sinista32
You're right on with the price $250 from nissan for that sender
But before forking out the cash for either I decided to pull my pressure gauge off the other car and see what's actually going on
The pressure definitely is dropping but not to zero like the factory gauge is saying
Its dropping to around 1kg/cm
Which at normal idle will sit at 2 kg/cm
And under acceleration raise to 6kg/cm
Anyone know if these figures seem normal? ??
Cheers
Ohhh awesome looks the pressure figures are sitting well within reason
Suppose I should just get a new sender anyways but at least ive rolled out having to pull the motor out now :)
Thanks for the assist guys
  • Like 1
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
