Fear not QLD cuz reinforcement is here.
ONE IN A ROW ??? Think I should get some of the admins to change it to ONCE EVERY EIGHT YEARS!
There was some bad calls that could have changed this game in favour of QLD very fast.
NSW got this one but only just - and that was on there home turf.
QLD I thought was better team........................wait wait wait - it is a better team :P
https://www.sau.com.au/forums/topic/444612-one-in-a-row/#findComment-7315943
Just like Queensland then, so both teams got away with it, so it can't be bias if they were both doing it
You are right in saying both teams did it. You are wrong in saying both got away with it. One team was penalised twice as often. So yeah it can be biased. And I am not actually claiming bias. I am claiming shit refereeing and this time QLD was the one that suffered. Next time QLD could benefit and I would still be pissed off. At this level refs should not be deciding games
https://www.sau.com.au/forums/topic/444612-one-in-a-row/#findComment-7315953
I agree this ref should have been dropped after the first game.
But there were some calls that could have seen nsw score earlier as well but we will never know
No sam dropped it, ive seen a tigers try taken away under very similar circumstances
https://www.sau.com.au/forums/topic/444612-one-in-a-row/#findComment-7315958
Sam's try wasn't in my opinion. Correct ruling.
Not a good end result on the Scoreboard :/
celebrate your win Blue's. Congratulations :cheers:
Honestly, If it was me I'd still be disappointed in some of your teams performance.
Gallon, Bird, Farrer, Watmough and even Hayne were a disappoint.
Gallon, Farrer and Bird hogged the ball too much trying to be the HERO and win the game in a team sport. The score would have been so much more in your favour if not for them.
I didn't even know Hayne was on the field till he ran 40 meters (over his dead ball line). 10 seconds left and the blues still in fear of a loss, says a lot in itself.
Call me one eyed but a better team lost on the night.
A slap, Pffft. A headbutt, Pffft - really? Soft much ?
https://www.sau.com.au/forums/topic/444612-one-in-a-row/#findComment-7315960
Why is it NSW won yet my fb news feed is full of NSW supporters complaining that the crying will begin from QLD supporters, and there has been maybe 1 or 2 QLD supporters even post :glare:
No wonder I don't follow the game, I wouldn't know if I am meant to have a cry or not win or loose!
https://www.sau.com.au/forums/topic/444612-one-in-a-row/#findComment-7315962
that slap was the best - good ol Thurston made laugh
Intense game it was - that's why I like state of origin
The passion each team have makes it all worth watching
The refs - shhhhhivers they will look at some footage and go 'yeah I f**ked that call up' lol
Bring on next game but more importantly next years Origin series
https://www.sau.com.au/forums/topic/444612-one-in-a-row/#findComment-7315972
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
