Yep, plus the speeds are different.
Naturally these are sprint day speeds NOT happy laps speeds.
I normally enter the main straight at 100kmh and enter turn 1 at 140, the exit of turn 2/start of the back straight is also at 140-145kmh, the entry into turn 3 is about 80kmh and during a race you're breaking as late as possible. As you can see you have the potential to be going a lot faster at the end of the back straight than the front and the corner at the back is much tighter and slower.
I am keen to test that out one day Mike
I'm surprised you still have standard brakes on the SS
The speed you are carrying on the main and back straights + breaking late on that national circuit must ruin them
QR don't run sprints on the National circuit, only their general practice. When I was out last I got good laps but on my 4th I has some serious brake fade at the end of the back straight.
Brakes are mostly standard, BDA4000 slotted rotors and EBA Redstuffs and braided lines with RPF600 fluid.
so just need caliper upgrade
Steal Gregos Endless kit :P
Okay, so, I may have overreacted to my coolant system failure last weekend...
Genuine hoses and ebay radiator.
20588e87-bf66-4a12-a2dd-e28d0438731d_zps
probably the only part under the bonnet you can get too anyway,lol,that should fix it anyway.
Speaking of brakes - I know this is probably the wrong place to ask, but the right place for the people I'd respect the answer from most - what should I put on a V36 350GT? I have a very bad habit of warping or hotspotting discs in all my previous cars, and want to nip this in the budd before I start doing any damage.
was it you in that silver 350gt at last Happy Laps?
Not me, and I sure as hell hope it wasn't my car! Mine is Blade Silver...
I only just got it this week. So unless the dealer was giving it a thrashing I doubt it was mine! :P
Got any footage or pics, I could probably ID it if it was mine...
Edited by Simink
15 mins into mike's commentary lols
Next time less engine noise and louder commentary mouse! :P
What was so funny? My saying the Evo had fulleh hektic stretch?
Buy me an external mic then.
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
