I have a very bad habit of warping or hotspotting discs in all my previous cars, and want to nip this in the budd before I start doing any damage.
http://www.mossmotors.com/sitegraphics/pages/brake_discs.html
change to better than factory pads and brake fluid for your driving application, replace factory discs with better ones also help.
FYP
Lol
What was so funny? My saying the Evo had fulleh hektic stretch?
There was quite a few gold quotes in there really. I've forgotten them all now though :P. But yeah mainly this:
I thought the general "I turn happy laps into angry laps" vibe was the funny bit... :D
Buy me an external mic then.
No.
No.
Like, 'is that an old evo or just a dirty f**king lancer'?
Then you have to put up with my engine noise.
I like the one where you say 'I was going to....but then I realised it's Mr Ants and he might get butthurt' farkin lol
Speaking of brakes - I know this is probably the wrong place to ask, but the right place for the people I'd respect the answer from most - what should I put on a V36 350GT? I have a very bad habit of warping or hotspotting discs in all my previous cars, and want to nip this in the budd before I start doing any damage.
Depends on which calipers you're running. If it's the basic ones, scrap them and replace with either Akebono or R34 bits. Akebonos are about $2k though.
Also take a look at what rotors and pads you're running. The right mix will help but if the size isn't right, you'll still get heaps of brake fade. I am the master of brake fade! :P
RDA slotted and dimpled combined with QFM or EBC pads should give you a good go.
Thanks mate :cheers:
I am planning on RDA slotted and dimpled with EBC Red Stuffs in mine...
I gotta admit... jibberish... all jibberish! :P
I have much to learn. Maybe one day I'll be able to afford to have a dedicated track day car to put my money into - and maybe then I'll understand what "RDA slotted and dimpled" means without automatically picturing some exotic condom style.
my mate took the photos and gave me links to them, so I just posted them up as is... I don't know much about photos/compression but it sounds like you need faster internet? :P
should you post more dirty Evos in the future just save them on your desktop resize the pix like 1/3 and then post them up (I use photobucket or my mobile to post all my sexy photos)
Flickr should offer compression by changing the "_o.jpg" to "_z.jpg", or other letters. None of them work.
I blame your friend for not allowing Flickr to auto-compress linked photos.
Either that or he's shared his view address, not the public address.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
