Im guessing it was overfilled by atleast 2 ltrs but it was never blowing as much snoke the. Last couple of days so doesnt make sence.
We will see soon what happens but atm still no idea
You must have some idea.
It's either due to your crazy overfill.
Or engine has busted some ring lands
Or turbo seals have gone.
As discussed in this thread.
  • Like 2
Oil dipstick being forced out also sounds like excessive crank-case pressure build up.
Could be worn rings creating excess crankcase pressure or blocked breather setup not allowing crank to breathe.
Excess crankcase pressure could also cause oil seals to leak..
Ok my comp were 160s across the board.
I changed oil put oil thickner in it and it stopped blowing blue smoke under boost only sometimes and now it just blows on idle when revving blue smoke occurs and when coming of the excellerator underload it blows blue smoke
Its now blowing alot of black smoke and big flames and all of a sudden theres no performance in second gear!
Third gear is coming on boost but not as it use to very slow and not as crazy. My dipstick is blowing anymore and i checked my pcv hoses including one to the turbo and theres only a smir of oil but theres smoke coming out of the hoses have no idea what that means but no oil at all? Im leaning towards turbos only because the performance of the car is really bad and it all of a sudden running really f*kn rich?
Any thoughts i will not purchase a catch can if theres no excessive oil coming out the breather system. Maybe valve stem seals?
Any ideas im leanig towards turbos guys but again therre was only a smir of oil in the intercooler pipe nothing crazy
Yeah maybe you should stop driving it so much while there is a definite issue with the car, you could have even destroyed the turbos running that much boost. Park the car up and remove the intercooler piping to the turbos and have a look there like the guys have said. There shouldn't be very much oil but if there is pooling there that is your issue. Pull the dumps off at the rear of the turbos and have a look in there as well, you might be missing the exhaust wheel on one turbo. If you haven't got the mech know how to get that done just tow it to your mechanic and leave it there until it is diagnosed. It's not worth destroying your engine by running it and trying to boost while you have some major oil issue.
  • Like 1
Ok i am guessing it is valve stem seals as comp test shows all same readings across the board.
Turbors are very non responsive but still making boost just not as aggressive so thats 1 problem but im saying valve stem seals purely because it now happebs in 3gear and 4 th when i give it to about 6-7000rpm abd deexcelerate and let the rpms fall smoke gushess out everywhere like a bush fire abd its blue. Its there when im boosting it but jot as much as when im deexcelerating the car so my gues is valve stem seals i put oil thickner with 10/40 and did nothing at all?
Nothing no smoke when i remove cap or dipstick! When i remov the hoses for pcv system i see smoke coming out of the hoses?
Just a bit like very little smoke.
I will rip of all the piping tonight and look closer to the intrcopler for oil because i removed the big ass intercooler pipe near the Y pipe and smir of oil pn the pipe so thats why i discard it from being turbos though ill take of the pipe to the cooler and see if its all hanging down there i want an excuse to go single loll
The fact it doesnt do it on idle when cold shows me its only on revving down from high rpm and underload on boost and on idle when revving it!
I dont think turbos it might be but i dont think so there was a smir of oil in Y pipe i think valve stem seals or maybe a piston ring landin
The pinging was only here and there maybe happened 5times worse was 109 on knock sensor but after i changed spark plugs and drove it around stopped happening doesnt happen in any gear now?
Smoke accured after laat drive on sunday
Valve stem seals tend to show when you have let the car sit for a bit then take off. Does it blow smoke on startup after leaving the car for a few hours? If not I highly doubt it's valve stem seals.
Also I wouldnt be putting oil thickiner in an engine that takes thin fully synthetic oil
Cylinder comp test on cold i just did one on warm showed those results im not to worried about 1-5. They all show same its number 6 at 70. Now the question remains why it happened and what part went wrong and do i blame my tuner it lasted 2 days of dyno
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
