Hello, I am having trouble with bad wear to the inside of my tires. My car is not that low but I have a little bit of camber angle and I was wondering if I get adjustable arms if my wheels will hit the arches. I got a wheel alignment done and have te figures on paper if that will help any one. I just need to know if It's worth me fitting them of not. Thanks
https://www.sau.com.au/forums/topic/444869-adjustable-camber-arms/
I don't really have much wear on the rear it's mainly the front, the tires have worn away a strange way also. It's warn on the side but not evenly around the edge, it's hard to explain. I got it done at autotec on sherwood road, I think it's in rocklea.
Without telling us what width/offset your wheels are, no one can say for certainty what will hit or clear...
Yes. Having adjustable camber arms will give you some adjustment to "tuck" the top of the wheel under the guard. However, no amount of camber in the world is going save you if your wheel width and offset are ridiculous...
Edited by R32Abuser
Tyres dont look too bad. A little less camber is probably better for street tyres. A set or two of adjustable bushes should be enough, and will still be legal. The reduction in toe you got might help a bit too (and should make it a little more eager to change direction).
U might be better off getting suspension check done at fulcrum or pedders then before swapping anything camber, make sure nothing's worn out. I had combo of control arm bush and ball joint wear, killed inside of both front tyres.
  • Like 1
I'm having a similar issue with my BNR32. Put it up on the rack to do an oil change, and the front tires were completely corded on the inside! After only 8,000 km!
The car is pretty low, but do R32's gain THAT much negative camber when lowered? Tire size is 245/45R17.
Are adjustable upper control arms the answer?
yep and yep
As per above, depends on a few variables as to how badly your tyres will wear. But yes, lower your car excessively and expect the inside to "cord" unless you install adjustable arms/bushes...
as I understand it, too much neg camber can wear out the inside of tyres, but wrong toe setting will *prematurely* wear out inside of tyres, as a result of them 'scrubbing' across the surface rather than smoothly rolling.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
