R32 Non Sunroof Half Roll Cage Into Sunroof R32 It Can Be Done!
So! After much searching for a r32 4door roll cage for sunroof model I gave up! Can't be found! For me anyway...
So I bought a used r32 4door half cage non sunroof from a member.
To install the cage all I had to to was trim 30mm off the bottom of the hoop that wraps around the passenger and drivers side seat. And re weld the base plates back on. There was enough play in the bars and wheel arch for the rear posts that I didn't have to modify them.
I imagine this would be the same for the 2 door.
So just to clear it up. A non sunroof half cage will fit a sunroof model. Only mod is to trim 30mm off the main hoops legs!
This was a cusco half cage.
Ill upload some pictures later.
Cheers
  • 3 months later...
  • 1 year later...
