i suspect it would only be for serious buyers who put down a deposit.
also, i am not sure when this car was deregistered in japan. from what little i know it has spent time in the united states, another thing that scares me is that it might originally have been a motorex car, which raises questions as to its importation status. the seller claims it's legal and registered in canada however.
we are on national holiday here in canada. everyone is closed. i'm going to be left with more questions than answers for the meantime.
i am also hoping for a test drive. i've never been in an r34 before, only r32's. if it ends up being slower than what i have now serious man tears are going to be shed.
Edited by DN1097
Depending what you are after obviously. Modified, unmodified or lightly modified.
Personally I would choose the first one. It appears to me to be more honest than the following 2.
However, if your looking for speed then heck yes buy one that's been modified (PROPERLY with paperwork by a reputable performance garage)
yeah depends what you're after...the R35 will be significantly faster than the R34 especially after supporting mods.
The R34 will be a classic like the R32 and the KPGC10, but perhaps not for another 10 years.
i met the owner of this GT-R last week:
10479136_10152586676453134_4542792734389
he told me he knew of the GTR i originally asked about above. the car is being sold on consignment, hence the markup and quite possibly why i have not seen it at their lot because the owner is driving it... oh well.
the owner of this car did quite well for himself. he spent a long time finding this one. it is a grade 4 car with B interior. i am not certain why it has a B rating because the interior was mint and had not been smoked in, but there was a lot of aftermarket electronics like a boost controller, defi gauges, navi and a tein edfc that were not well/permanently installed, which could be the reason why, but he has since sorted it out. he bought it himself at a tokyo auction house (i can't remember the name) before it was 15 years old (as per canada import laws), but had brave auto international to store it until it was and it was shipped by container to canada, and here it is now. he paid almost half of what the one i was looking at was asking for. sigh.
Edited by DN1097
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
