I know there is ALOT of topics like this but I would like to see what people have to say about my plans.
So I am looking at buying a completely stock r33 GTR (got one insight) and have got the following mods planned (not very mechanically switched on like you guys which is why I need your opinion)
Blitz nur spec r exhaust, decat, front and dump pipes, blitz front mount intercooler, apexi induction kit, coilovers, wheels and tyres.
If anyone has a idea of what power gains I will get from that I am very interested to know. Also if there is anything I am missing (I know there will be) please let me know. Looking to spend 5-6k on mods to start.
Thanks
https://www.sau.com.au/forums/topic/445054-stock-r33-gtr-mods/
Leave the stock intercooler in there and leave the stock intake alone as well as they are both fine for 400kw at the wheels. Also don't change the dumps till you upgrade the turbos
spend the money you save on an ecu and tune those 2 things will make a massive difference
  • Like 1
What ecu would be my best option? Doing what you said would save me a lot of money. Thanks
There are lots of plug in options
Power fc is well known but a little limited by today's standards
Haltec, link, vipec and a few others as well, talk to who you plan on getting to tune it for you which they believe is best for you
  • Like 1
Just do:
  • Exhaust from Turbos back.
  • Upgrade injectors.
  • Maybe upgrade fuel pump.
  • ECU
  • Boost controller
  • Splitfire Coils.
This should get you very noticable power upgrades without costing you a liver and keeping a nice stock appearance.
Bob.
Depending on age/condition, I'd look at an oil pump too, to avoid grenading things when the power goes up.
The thing is that's an engine out job. Which is a fair bit of work just to do the pump.
There's the whole cost : benefit : risk analysis to to be done.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
