hey iv recently bought a r33 series 1 mods
Apexi power fc
front mount cooler
z32 afm (new)
yellow jacket coil packs (new)
new plugs iridium ngk heat range 7 already gapped to .8
new fuel filter
Ok so i bought this car recently went great when i got it was unrego so i decided to service it before putting it on the road i put some new spark plugs in same as what came out of it with new fuel filter cleaned maf and put a full tank of 98 in it ever since the car hasnt been boosting properly slight hissing sound checked for vaccumm and boost leaks none i can hear a slight whine on boost only seems like a air valve is stuck open???Has knock readings on hand controller goes well cold then warms up gets worse has bad fuel economy can ease on boot without knockin bad but if plant it goes nuts poping not sudden jerking just lack of power when warm and backfiring when try to limit usually change gear before boost 2nd stage
Things iv tryed
Checked for boost and vacc leaks
Replaced spark plugs
Changed oil and oil filter
Repalced MAF
Replaced coilpacks yellow jackets
Cleaned iac valve
New Fuel filter
tryed different tank of fuel incase bad fuel
Factory heat range for spark plugs is "5". Unless you are making serious power, you shouldn't be using "7"s.
Have you cleaned the injectors (remove and sonic clean, not a just bottle of cleaner)?
Ok I reread your first post.
It went great when you got it. So that means something you did made it run shit.
It could be the coil pack loom as they get old and brittle and don't like to be jiggle.
What boost are you running?
its running very rich 300km to a tank iv try'd all the heat ranges from 5-7 with the spark plugs
only just had the timing belt done was missfiring before i had timing done
i rang my tuner he said maybe cat converter?
randomly has power then others just nothing but slugish its running 12psi
Sometimes i feel a small surge of when its going in and out of power then 10 minutes later will be shit again goes well cold
i also found one day it felt like i was pushing the throttle in was very stiff like i was pressing against the psi in the motor or somthing wierd hasnt done that for a while dont know (bov may have been sticky didnt drive for a while?? stoped the car pedal went soft again wtf? lol
the exhaust does stink how can i check my cat
when the knock sensor stays flatline it goes good instead of slowly creeping up the graph the more i throttle it on the power fc no power after 4k rpm
(Thanks alot for the replys!!!) first time posting really apreciate the help
If it smells like rotten eggs that is a sign on a bad cat, you can try tapping it and seeing if it sounds hollow or if it sound solid. take it for a drive so your car is nice and hot and measure the temp on each side of your cat, should be roughly same temp.
But I am with Ben on this one, pressure test your system, I was having a lot of problems and I never bothered to pressure test because I didn't think I had any leaks as I still saw 7 psi on boost gauge, decided to test it as I ran out of ideas and turned out a weld along the side of my Intercooler was split. Car run like new now haha
knock sensor creeps even on idle
not when cold though just stays nice and flat once warm it goes up and down slightly
im no good at explaining but when the thing stays flat its fine sometimes just decides to stick around 20 on cruise and feel like a slug
i didnt do a pressure test but it seems to boost fine when it wants to seems sensor related :S i can hear the note change and torque straight away when it decides to go normal for few minutes
Boost leak will affect sensors as well, your intake sytem may have a leak, so your turbo is working extra hard and pushing large amounts of air through your system, but not all the air your turbo is pushing out is getting to your engine, which means your air flow meter will be giving false air measurements to your ecu, and this will give you a bad air/fuel mixture depending on how bad the leak is, and may cause your car to run like shit.
so ive had my swap done now for about 2 months into s13(bought from a friend was running and driving with no problems). put it in got it running, ran like crap knock sensor was unplugget and I put new plugs in, fixed ran awesome. the biggest plug gap I can run is .026 or it cuts out maybe that normal but that seems kinda small to me coming from sr to 1j and now rb(should have stuck the 1j). that was an sc300 though. anyways my car kept going into limp mode like I had a bad maf and it would fix itself on its own, it never does that anymore though.
now after it warms up it has vary noticeable power loss and it even sounds different, like its pulling timing or something.
things I have done
was throwing code 13 got a new coolant temp sensor didn't change
checked voltage at ecu for knock sensors they were both 2.5v at idle
set tps and made sure it was correct when set while wot and closed
boost leaked checked multiple times and its solid
haven't messed with bov still recirc
tried 2 different fpr's and new z32 fuel filter
put extra grounds from block to chassi and an extra ground on coil pack harness
checked voltage at fuel pump 12 volts
when I put the motor in the timing was set at 20 degrees according to how you look at it rb's its kinda weird depending on the angle you look at while timing it. it had been that way for a few years with no problems im timing by putting my timing light on the white wire at number 1 coil with the timing light hooked up to a jump box for power because my battery is in the trunk. maybe that's all no good and need to make a wire from the coil to the spark plug and use that to time it?
now after about a week it throws coolant temp code again, so I ohm the wiring between sensor and ecu and I doesn't say offline but it reeds o.o ohms. I check the ground and its 3. something.
info about the swap
s1 rb25 mostly stock
I think its an older wiring specialties harness but its a little old now
hks actuator set to 9 psi
n1 thermostat
walbro
pulled from my friends running s13 and about 3 weeks later running in mine
pumped all old gas out of my shell and put new premium in
cx racing front mount
3 inch dp and exhaust
I don't mean to ramble on to run so good and strong sounds good while its warming up, and I don't mean dead cold and romp on it I wait till needle starts to rise on temp and pulls hard all the way to redline, then temp gets halfway up and gets slower and slower till it sounds way different and feels like has no boost just a na motor, still drives smooth though doesn't cut out and super rich. I don't have a wideband but it uses tons of fuel and backfires a little usually when I take my foot off the gas and start coasting.
ive tried everything I can think of and before I rewire my coolant temp sensor to the ecu I figured I would ask. ive b
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
