RB20/25 Stainless Steel exhaust manifolds
Guest darrinspencer
If we can get minimum of 10 people together, I am able to get Rb20/25 T3 Turbo Stainless Steel exhaust manifold delivered to Brisbane from the USA including Customs and GST for $490 each.
These are sold by Stone racing in the USA and made from 2.6mm wall thickness and 42mm primaries.
Once we have 10 or more people together, I will require payment upfront. Once everyone has paided, I will order and pay for the manifolds. Delivery takes approx 14 days. Once they arrive you can pick them up from me in Brisbane or I will post to you at your cost approx $20.
List of people wanting one
Darrinspencer (confirmed)
51jay (confirmed)
tonygtst (confirmed)
Muaythailuke (confirmed)
TurboX (confirmed)
Vlv00m (confirmed)
Maybe's
Zoix
Camandcandice
Slyr33
GTT23
SQN180
Bbenny
Adzmax
Bbenny
Brod
  • Replies 49
.. i should probably pm about it .. but someone else may like to know as well
in relation to the stock turbo mounted position .. with these manifolds will the turbo remain in the same position or is there more modifications needed after fitting the manifold? ie the oil lines and pipiing etc
Matt
I wanna know if it's a 'slot in/slot out' proposition - re-use gaskets etc.
Then we will truly know if it's an economical and measureable difference.
T.
Guest darrinspencer
I sent off an email to ask
1. Does the turbo remain in the factory position.
answer- Yes
2. Are there any modifications needed to fit the manifold eg oil/water lines etc
answer- No
So what they have told me, the manifold should fit without any problems.
Please excuse my ignorance, but where exaclty does a starndard turbo sit, as I drive a VL with a custom exhuast manifold(rb25/30 combo). I would like to get one of these but it looks by the photos that the turbo sits on a weird angle. I just would hate to get it and find that I can't get the bastard to fit, thats all.
Is the price of 490 straight to my door? Or is there another cost involve?
Also what sort of increase would these give, on stock and aftermarket turbo.
I may be in but would have to wait a week or so before i can give 100% ok.
Also if u get 10 people, will u allow more? Or is it 10 max?
Guest darrinspencer
Need a minimium of 10 people, more people is fine.
Cost delivered to most capitals will be $20.
$490 is to Brisbane, as stated in the first post. Customs and duty and freight from the USA is included.
If we can get the 10 people plus, will order them once everyone has paided up front. Hopefully in about 1-2 weeks
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
