FOR SALE!
R34 Tail lights sedan $50 a pair come as pictured
post-44496-0-51362600-1406088668_thumb.jpgpost-44496-0-44151800-1406088688_thumb.jpgpost-44496-0-14844000-1406088707_thumb.jpgpost-44496-0-78735000-1406088719_thumb.jpg
GTR gear knob $30 excellent condition
R33 GTR fuse lid cover interior, great condition (should also fit gtst) $10
R32 A pillars $10ea excellent condition all clips perfect
R32 under dash panel avg condition $10
VERY RARE GENUINE R32 GTR intake plumbing, comes with bracket and mount, sits under passenger guard $100
post-44496-0-73601300-1406089153_thumb.jpgpost-44496-0-68120400-1406089264_thumb.jpgpost-44496-0-82613200-1406089335_thumb.jpg
R32 front Nismo strut brace $120
post-44496-0-35289700-1406089505_thumb.jpgpost-44496-0-53557000-1406089533_thumb.jpgpost-44496-0-14412400-1406089642_thumb.jpg
Genuine R32 Nissan skyline rear strut brace $100
R32 GTR (suit all models) textured stereo surround, perfect condition, clips unbroken no marks or cracks
$90
Located Gold Coast
Will freight Auswide
Johnny 0414596256
  • 4 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
