I have just recently found out my RB25 turbo is on it's last legs so I thought i might aswell upgrade it while up there. I have heard of people saying good things about
Kinugawa Turbo's and just wanted to come on here and ask what the overall opinion of them actually were
Eventually I would like to achieve 350hp on a stock Bottom End RB20 is this acheiveable?
If so what turbo charger should I be looking at getting? I've heard TD06-20 are good for 20det's am I going in the right direction on this choice?
anybody on here with a 20det actually ever bought one of these turbo's got any feedback on relibility/performance/ ease of install (completeness of the turbo kit they sell)?
So far i've been looking at this which seems to cover everything you'd need for the install, but if anyone has installed one of these before, does it?
Link below incase hyperlink doesn't work:
http://shopping.kinugawaturbo.com/kinugawaturbochargerbolt-on24inchesnissanskylinerb20detrb25dettd05h-16g8cm10cm-1-2.aspx
Edited by angusis2fast4u
https://www.sau.com.au/forums/topic/446083-qs-about-kinugawa-td06-on-rb20det/
people seem to struggle getting the bottom front nut done up turbo to manifold
as the casting is to thick on the flange to get a spanner on there something to keep in mind
I was going to have to remove the core fit the rear housing then refit the core
or I was told by a mate he took to his with a grinder
What do you mean by 350 HP? Fly? Or at the wheels? Reason I ask is that you can pretty much do 300HP at the fly on a stock RB20 turbo, get reasonably close to 350 on RB25 turbo.
By the same token....I first saw ~350HP at the wheels done on an RB20 with a TD06 in about 1998. It's not hard. You can shit that amount in on stock bottom end.
At the wheels man haha
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
