Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
That's good news.
Shit tune confirmed ...... flame suit on.
Unless it's the mysterious gates timing belt ignition scatter issue.
Edited by Ben C34
  • Like 1
Im hoping its a shit tune- despite taking my car to Unigroup 3 times, they just couldnt fix that bogging down prob, they went over but didnt touch the tune which they claimed is as good as it can be, their after-service is good.
I still have my pink label R34afm which I wana test though to see if the z32s farked. And maybe test the pcv valve cos boost went to the crankcase oil vapor vent area. And change O2 sensor.
what about a worn harmonic balancer/ key if it was moving or loose down there wouldn't that give some of the symptoms?
Edited by AngryRB
Yeh I was meaning change the powerfc settings to r34 afm after putting that in. Harnonic balancer/keys fine, I inspected that/ did the timing belt myself.
You guys still dont reckon my O2s shot? Drives much better with it off. It must have been richening my car like a pig in the past.
Also dont understand how my dipstick was never blown off while driving all the time at 22psi but now with the boost leak test at 19-20psi it shot off like a rocket! Lol
Keep it disabled then
Even if you choose the right afm you'll be surprised it might not run properly. If the afm was again rescale your fuelling will be off
The stock map sensor isn't referenced by the PFC as I said yesterday. Turn 02 feedback off. Like I said yesterday, your fuel economy usually won't change a great deal with a Unigroup tune. A new sensor is cheap enough and can be replaced at your leisure.
The PFC handcontroller item BOST (or whatever it is listed as) is for when you are using the Apexi boost controller IIRC.
What doesn't make sense is that you mentioned that you car was pinging...a rich environment won't cause it. There is something that isn't right with your ignition timing, I think. When it pings or idles crap is your engine noisey, like a belt shutter, noise, or something else. Sorry but what you are describing doesn't make sense.
A shame u don't live in nzwould have the datalogit plugged in and checked by now.... I'm beginning to suspect tune. Did they do your accelerator pump corrections if they were left stock it will go mega rich on gear changes.... Mine was going to the 9s before i tuned it out.
Thanks mate, so I will leave the O2 feedback off till I get new O2 sensor (I know irts preferrable not to have O2 enabled but my car was tuned with it, so its best I leave it ON? Or not, and heres my accelerator pump enrichment that you asked about, do the adjustments look ok?
The O2 sensor should only be fine tuning the mixtures. It should be tuned woth it off to give the correct mixture, then turned on and checked after the tune is complete. It should barely make a difference on a properly tuned car whether off or on, especially immediately after being tuned.
Again, refer to your tuner. Ask him. He tuned it. We are guessing. It should be running 14.7 at cruise (pretty much) with or without the sensor. Which it doesn't seem to be due to your consumption.
i run my car with the o2 turned off permanently. those injector settings looks like stock settings. mine are attached but are for 850cc injectors....but they still make it fairly rich.
starting to sound like your tune didn't take everything into account. e.g wot & cruise only.
turn off your O2 feedback, better yet just disconnect it.
Tuners always turn it off when they are tuning to disable the trims.
as for your acceleration enrichment, just set it low and work your way up till the car stop buckling.. sometimes it worth adding in more decay.
you have to adjust these like any fuel trims with a wide band. you can log and see the effect of enrichment when lift off and mashing the pedal, this is what a tuner would do if they are doing a complete tune.
yeah different AFM different turbo = different values required
just write it all down, and start decreasing it for the RPM affected.. might actually reduce your buckling
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
