Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Overrun/overrev on downshift.
Also, and by the way, when you say "wedge" do you mean the ridge of high timing running along the top, or do you mean the little dip right at the end closest to the viewer?
that little dip in orange and yellow closest to viewer - just two values of 30 affect this.
Nope, had a play in Excel, those two values of 30 are a big jump from the adjacent LHS values of 40 & 43, making them say 38, 39 smooths it out, the tuner was probably eating his pizza and forgot that - but then again I doubt these two odd cells will do 'anything' to how it drives.
Saying that - what do you guys think of that purple 'hole' in my fuel map (mid rpms, low/mid load), is it dodgy or kinda ok? These are values from 84-94 on this area of the table
Edited by rondofj
Fuel map looks fine. RB25 motors like less fuel around 50kPA when compared to near absolute or 0 kPA
Also around that area timing starts to decay when compared to higher vacuum areas.
It's normal man, you can't just look at the fuel map and go "oh mah gord deres a fuel hole"
Simply put it the motor isn't needing fuel around there to hit stoich.
  • Like 1
Cool man I take up your offer of swapping afms in the weekend, but I think I will need it for at least a coupla hours to test in diff loads/conditions if thats ok? And also if u can come for a quick drive to monitor things who knows u find something I didnt. And James Squire will be there too so dont worry.
Datalogit kit is money wasted just to diagnose a problem/quote]
You won't do this but you will buy a new ECU? And the old ECU had data logging? And you don't like how the car drives and this issue has been happening for moths and you have spent countless hours trying to solve the issue?
Ok.
  • Like 1
So eventually when you manage to log what's happening, and see that the ecu Is jumping cells, due to the afm being affected by the bov return, what are you going to do then? The afm can't be faulty only when lifting off the throttle.
The only two options here are shit tune or an issue with the bov return. The tuner is well respected, and it's pretty hard to do a shit tune on a power fc after I'm sure he has done 100s. So that leaves the bov return.
I am sure you mentioned this on page 2 of this thread....
well as I've said a few times already - I'm not too concerned with the power loss on shifts right now (its a MINOR issue and is most likely the bov return as others have said). What I am concerned about is where has my power gone the last 3-4 weeks without changing anything and the rich running (fouled plugs, fuel smell, fouled O2 sensor)/ fuel economy is my main problem that I'm trying to fix. We will see about the economy on my next fill-up as I changed the O2 sensor - but expect bugger all difference.
Which leaves AFM as suggested by some.
And tune? Well you've all seen my tune now haven't you, are you able to tell if its shit or not cos I have no idea
Reversion will cause the symptoms your are describing
Its hard to look at a tune map and know anything about it without seeing its effect on the motor
Your timing isn't to far out there, maybe a bit advanced at high rpm low load but nothing that is going to cause the issues you are describing
Disconnect your BOV from inlet pipe and vent to atmo and see if power lose is still there, that will either confirm or rule out reversion
Yep will do that cheers. Meanwhile figured out how to do a map trace. Still a noob u see .
See pics -1st one is a 10-12min cruise to shops, parra to granville in syd, traffic lights, stops max 50/60km/h NO boost.
2nd one is same drive back with three 2nd/3rd gear pulls at 21psi max. So does it look like its accessing the right cells or has it gone a bit gay?
Edited by rondofj
Looks fine, however with logs with a wideband connected to it will easily show you what's going on.
It's hard to say what it is and not doing because the load axis is an interpretation of TPS and AFM voltage
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
