hey guys.
my names matt, and am completely new to the nissan scene.
have came from a subaru... so there is ALOT to get use to and such.. but i'm loving it!
traded my 03 XS luxury model Forster for a mint condition 96 S2 R33 with 133k on the clock. only mods on it so far are a 3 inch TBE with seperate wastegate pipe on the dump, HKS cannon, pod filter, GFB atmo bov, HDI boost controller w/ gauge and a set of ugly ass 20's :yucky:
but a clean swap for the forester, there was no way i was passing that up!! with more than double the power of what my forester had, i'm more than pleased with my purchase :D
went from this,
10420276_246493432217497_646458104418218
to this,
10403023_260654300801410_753650757885877
so looking forward to meeting new mates and getting amungst the fmorum!
https://www.sau.com.au/forums/topic/446154-new-on-the-block-newcastle/
might want to fob off that atmo bov because afm car no like atmo bov.
yes its on the list of things to be removed. will be getting a plumb back bov amongst other things (fmic etc etc) then it will be off for a tune when i get the money.
out of curiosity what does it affect with the car?
the afm measures airflow going into the engine, using that information, tells injectors how much fuel to put int, while the atmo bov releases intake charge into atmosphere, which upsets the whole air flow measurement, so you overfuel.
that is my understanding.
ahh yeah well that might explain why my fuel consumption is dog shit lol.
need to get me a recirc. bov asap!
That can be a number of things... Find yourself a decent tuner that has an idea of what is going on and that should soon be sorted :)
GuiltToy (Anthony) is back tuning in Newcastle, Bellevue have a Mainline dyno now too... You can travel a bit further and see Jez on the Central Coast (He is a guru)...
My advice would be to avoid a certain shop... Starts with B and ends with lacktrack! Myself and many others were left with a bitter taste after being ripped by them in the past...
Enjoy the car and stay away from Newy on Thursday nights!
ahh! i just hit up jez. he tuned my mates RWD forester and done a pretty good job.
thanks man :) yeah definitely staying away from that defect station.. haha!
Jez is good value! And will certainly help you sort your fuel economy issues too!
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
