Hi people, this car is really starting to do my head in! Car has never thrown a cel or missed a beat. Here goes car has new hi flow turbo, new plugs, pressure tested intercooler set up new intercooler claps etc etc . new big trans cooler , full trans flush. Does not use oil. Big dump pipe, hiflow cat 100cel. Car use to pull like a train, but not any more its sad. All it does now is bellow grey black smoke and lucky to out run a hyundai xcel.. Im lost for ideas??
https://www.sau.com.au/forums/topic/446280-slow-and-smokey-nm35/
Should'nt that throw a cel but? Plus it surges on and off on boost.. Like the gate on turbo opening and closing constantly even holding your foot on throttle at the same point. Should your waste gate actuator have a tension spring on it? Mine does:-/
Probably is the bov making noise, not the waste gate. Is it misfiring while it does this? If the entire intake from afm to engine holds 30psi then it is most likely afm or a misfire issue ie fouled plugs, coil packs, poor compression. Eg. Mine has had Intake leaks, fouled plugs and faulty coil packs and hasn't thrown a code. I believe others have had their afm die without throwing a code also.
  • Like 1
All sorted :-) Had turbosmart boost controler on pipe from intercooler pipe to tb, totally blocked so no pressure getting to wastegate. And hose from cam cover to turbo inlet cut off and pointing to the ground:-0 Im guessing till you get to pressure off vacuum car can suck un metered air until pcv shuts.. if im correct??
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
