k guys, i'll update this as often as i can.
Dont whore this thread o you'll get a warning.
Nice and easy - ash
Upcoming Sessions
WEDNESDAY 30TH JUNE 2004
WEDNESDAY 21ST JULY 2004
WEDNESDAY 11TH AUGUST 2004
Where: Calder Park, Calder Freeway Keilor
Cost: $100 per driver, Spectators $5
How to enter: All entries will be taken by Calder Park. Entry forms are available at www.fulllock.com and from Calder Park 9217 8800. Payment is recommended prior to the night. First come first served.
Car Requirements: Cars must be of a safe and roadworthy standard. Fire extinguisher and roll cage are not essential. Seat belts must be worn and of a safe standard, harness’s permitted. All lose items must be removed from the car.
Driver Requirements: Drivers must be licensed. Drivers must wear long sleeve top and long pants made of natural fibres e.g. cotton. Helmets must also be worn and are available for hire at Calder Park for $20.
Passengers: Passengers are not permitted.
Drift tyres will be available for sale and fitting at approximately $10 per tyre.
Happy drifting.
Adam Newton
Full Lock Motorsport Australia - Australia's Home Of Drift
Web: www.fulllock.com
Phone : 03 9824 7692
Fax: 03 9824 7939
International: 613 98247692
Mobile: 0419 504 338
https://www.sau.com.au/forums/topic/44703-fulllock-drift-sessions/
  • 1 month later...
http://www.fulllock.com/Drifting_entry_for...m_Indemnity.doc
Page not found
The page you requested was not found on this web server. This could be for a variety of reasons, including:
* You followed a broken or out-of-date link.
* You entered the URL for the page incorrectly.
* The page no longer exists.
If you followed a broken link, please inform the owner of the referring page.
  • 1 month later...
  • 1 month later...
Latest dates.... http://www.fulllock.com/forums/viewforum.php?f=1
Next practice night is on Saturday 11th December 2004
The price has dropped to $80 for competitors (they are clearly insane)
and the practice night is free if you are entering the Banzai Battle competition on the Sunday! *see below*
Also there is a competition on Sunday Dec 12 2004
p.s. I will probably be a judge at the comp, so if you wanna win! Bribe me!!!
  • 3 weeks later...
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
