Hey guys,
I am new to this forum and don't really have any experience with cars so please go easy on me!
4 years ago before I had my licence I bought my first car a 1993 R33 GTS-T. As I didn't do my homework on turbo laws in Queensland I have been unable to drive it on the road whilst I have my P's. So she has been sitting in my garage since then and has been quiet neglected! I am very busy with uni and work and therefore only get around to starting her up every 3-4 months, apart from a dead battery it usually starts up fine! In a few months I finally get my opens and will be able to drive the beast, I just wanted to know what my best options are in fixing her up to avoid any damage caused from this long period of neglect? People have told me that I will need to replace rubbers in the motor and all sorts of stuff (doesn't make sense to me). Any feedback would be greatly appreciated and remember I'm new to this so go easy :)
Cheers
https://www.sau.com.au/forums/topic/447303-r33-help/
Hey kyle94,
I would check oil level then warm up the motor and then drop the engine oil, replace with good quality oil and new filter.
Next flush out the radiator and put in fresh coolant, make sure it is the right coolant as the wrong one can cause corrosion, bleed properly!
Check the gearbox and diff oils as a slow drip could have drained them over such a long time. If you haven't driven the car the oils just sit at the bottom of the Gearbox and Diff so everything sitting at the top dries out a little, I would change the oils in these also after driving it a short time to make sure everything is warmed up.
Give everything a good clean so that you can see if anything starts to leak. Check it a few times in the first couple of weeks of driving.
Make sure has good oil pressure, and give it a couple of good drives. Change the oil filter after a couple of hundred Kilometres, just to make sure!
Probably check the spark plugs, if you have been starting it and letting it idle, could be blackened from carbon build up.
ENJOY!!!
Cheers
https://www.sau.com.au/forums/topic/447303-r33-help/#findComment-7375517
if you have only been starting it and not moving the car then I would also check you brakes. They could seize up after sitting there for a long time. I would bleed the brakes and replace fluids. Drive it easy at first to make sure brakes are functioning well.
https://www.sau.com.au/forums/topic/447303-r33-help/#findComment-7375741
When I start it I usually give a squirt up and down my 200 meter driveway, so I give everything a chance to move around! but I will definitely give everything a good check over, I gave radiator a clean out and replaced the coolant about a month ago!
Thanks for the reply MattZilla and Abdul11
Cheers
https://www.sau.com.au/forums/topic/447303-r33-help/#findComment-7376448
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
