HI,
I have BNIB Ruzic Engineering Attessa 4WD Controller.
Hands down best 4WD Controller on the market, soon to be out of manufacture.
Grab it quick before it's gone and can't be replaced.
Comes with all paperwork, instruction CD's, wiring etc, everything as you'd expect form a new purchase.
Sells for around $700.
http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=4_524&products_id=2642
Asking $450 delivered Aus Wide.
John.
This version has:
Auto (GPS) Map Select Mode - The controller can select MAP and SCALE automatically for each corner on a racetrack, up to 10 switching points per track.
Lap Data View Mode - Three sectors for timing can be setup, unit stores 12 laps of data. Displays live lap and sector data on screen during lap.
Pretty sure this version also has a faster processor, more memory and an upgrade in the mapping/calculations over the previous version.
Not plug and play but not much work to wire in either.
Just to confirm also, you need to buy GPS receiver to enable GPS features on controller as it's not included in sale.
Just had a quick scan through instruction manual. No mention of using any specific GPS antenna, just that these features are available once connected to GPS.
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
