Basically just wondering if people on these forums in NSW are involved interested in waterskiing and wakeboarding...
obviously it's not really the time for it (too damn cold) but just looking into some options to organise some outings/lessons for people..
Really just throwing around some ideas since it is a mad sport and a whole lotta fun!
https://www.sau.com.au/forums/topic/44744-wakeboarding-in-nsw/
have you got a ski boat craved? i ski behind my mates malibu 04 wakesetter vlx, so im fairly lucky that one of my best friend owns one :)
i'm usually up at windsor (sackville) most sundays and even winter... best water and no crowds! you can't get much better than that :D you just need a dry suit!!!
if you end up organising something, id be very interested.
duncan, i'll upload a wakeboarder behind a car tonite :)
have you got a ski boat craved? i ski behind my mates malibu 04 wakesetter vlx, so im fairly lucky that one of my best friend owns one :P
i'm usually up at windsor (sackville) most sundays and even winter... best water and no crowds! you can't get much better than that :P you just need a dry suit!!!
nice, no i dont have a boat yet.. a mate of mine has and old lewis we use sometimes, but usually go out in a Nemisis wake board boat with the guys from Trojan Watersports in windsor (boat used to outside the shop all the time)
Sackville is very quiet usually, wont go out in winter but... not that keen.. but yeah usually ski around dad's corner depending on the wind!!
BOO57A,
saw you out there today on the Putty cruise, i have to hook things up just an idea atm, but if i can organise a few boats and a few riders should be able to set things up!!
Nice ride btw!! i was in the black MR2 behind you most of the way, after my car didn't make it past the go karts :cheers:
Hmm Mate just sold his Wakesetter, my gf's old mans Childsplay still goes aight with a few conrete blocks and lead weights down the back, franks what were you behind in your sequence shot?? Wake seems too tiny for a Mal or is it just not loaded?? Going for a weekend at my GF's brothers bucks party so that'll be fun but effin freezin if we cum off...
heh, a mate has a house on gymea bay, hacking is nothing short of a washing machine imho :cheers: once a big boat goes through the wake just rolls through the whole bay! :D - but im sure if your out early enough its okay :rofl:
craved, yeah houseboat thing seems very cool. especially since theres nothing to do on a houesboat but fish! :D never seen that vid, but i have a few others i downloaded ;)
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
