Hi guys having an issue that's got me stumped so just after some advice or ideas. Motor is basically stock besides the greedy front facing manifold and a front mount, over the past week we installed a after market exhaust manifold, hi-flow cat with a 3 inch system from the turbo back and a 2 way diff now we have lost power dramatically the car was running 10psi fine before on the standard ecu now it won't go over 8psi and it drives like the timing is out or something could it just be in need of a tune after the upgrades or would it more likely be another issue somewhere? Any advice is appreciated thanks
https://www.sau.com.au/forums/topic/448157-help-lost-power/
Have you got an aftermarket ecu? How you going to tune it? You can' t really call changing your inlet and exhaust manifolds an upgrade. A bigger turbo is an upgrade. Having said that you shouldn't have lost much power. Have you moved the CAS at all? No 1 suspect is boost leak. See if you can test the system by pressurizing it and look for leaks.
https://www.sau.com.au/forums/topic/448157-help-lost-power/#findComment-7379922
Hi mate thanks for the reply I do have one but we haven't installed it yet we are still running the stock ecu I didn't think that was the issue but I was just throwing it out there as it was the only thing that would make the slightest sense I know none of what we did should of made much difference no we didn't touch the CAS and yer that was my first thought I checked over everything as best I could but didn't have the gear there to pressurize the system
https://www.sau.com.au/forums/topic/448157-help-lost-power/#findComment-7379926
Though it's not coughing or missing at all like it would with a boost leak just drives like it's severely restricted almost like someone has retarded the CAS almost all the way if you know what I mean
https://www.sau.com.au/forums/topic/448157-help-lost-power/#findComment-7379927
what exhaust manifold is it?
i had an aftermarket exhaust manifold that came in one of my old cars and it cracked at the weld, caused a noticeable power loss- went back to stock exhaust manifold which also helped with boost response
stainless exhaust manifolds crack easily
and what dump pipe have you got?
some short hks style split dumps may also catch the wastegate flap. though i've had two of those split dumps before and never experienced that problem
https://www.sau.com.au/forums/topic/448157-help-lost-power/#findComment-7379946
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
