Hey there guys just went to tighten down my seats to the floor a touch and my I got a touch carried away with the impact wrench and stripped the threads on two bolt anyone recommend a place to buy hitenstile strength bolts of the sam thread and similar length?
https://www.sau.com.au/forums/topic/448220-seat-mount-bolts/
Ok Cheers Scott same thread tap it is and some thread lock no?. M10 x1.25 sounds right that helicol thing looks pricey. While I'm at it I'll far up some spacers for the passenger seat.
Scott have you got the flairs for the axis still?
Grand cheers scott. I couldn't get any M10 x 1.25 so I retaped to 1.5 and grabbed some corresponding bolts and all is good cheers gents
I wouldnt say that's all good at all. That's heaps dodgy. How much thread do you think is actually holding now?
But it's only the seat. Not like it's the ashtray, or anything similarly important.
  • Like 1
How is it not its re tapped to 1.5 with new M10 x 1.5 bolts so all the thread holding now. The ashtray is held in with bluetac champ :-P
It's dodgy as.
If you are happy with it thats all that matters.
There's hardly any thread actually holding. I thought that was pretty obvious but it seems it isn't. I could draw a picture for you but really can't be bothered. Maybe when I'm at work I will so you can see just how little thread is actually holding.
Edited by Ben C34
Now, I'm no engineer but I don't think it's the bolt thread you need to worry about, it's the fact you retapped an M10 hole from 1.25 to 1.5. With the original tapping of the 1.25 pitch a certain amount of metal has cleared out, and overlapping the same diameter with a 1.5 pitch doesn't put back all the metal previously removed by the 1.25, it just shaves extra away, meaning the mating face between the bolt and hole is patchy, and alternates between a full face and almost nothing at all.
...Or am I completely wrong here? I've never had to retap a hole, only remove broken bolts that thankfully didn't damage the thread.
Surely to make a safe fit an M12 (maybe?) bolt should be used and a larger hole tapped accordingly.
Mate I'd love a picture I'll hang it on my fridge with the other kids drawings :-P
You should. That might show you why you should actually fix it properly. I'm not going to waste anymore of my time.
It is unsafe. Barely any thread is holding the seats in. I'm sure they won't fall out in general driving, and I truly hope your car isn't involved in a crash.
You are correct.
Although M12 might be pushing it. A helicoil would be better and will work.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
