Hey guys,
just had this built in Perth.will be on the car soon and tuned at the end of the month.be interesting to see what it pulls
Nissan VQ25 custom upgrade.
Billet GT30 compressor with ceramic ball bearings and bronze cages . HKS GT3035 turbine wheel used for great spool up. Major machining undertaken to make it fit but all in a days work here at Per4manz
https://www.facebook.com/pages/Per4manz-Turbochargers/227998503999398
  • Like 3
https://www.sau.com.au/forums/topic/448269-per4manz-perth-based-highflow/
Looks the goods, but I think you will have boost spiking issues unless you open up the wastegate hole and run a larger puck...
What is the thrust load tolerance like with the ceramic bearings? The small rear housing will cause a lot of pressure on the shaft. (partly why the Garrett cores have so many problems when shoved in the stock housing.)
I look forward to seeing what it can do, when is it getting tuned?
I raised the point of spiking issue's but grant has assumed me it should be fine (he gave me a full in detail description of it all too)
I have no idea the load tolerances but I'll ask when I pick it up today he's done plenty of rb25 turbos similar to ours,I know he changes the casing to a bronze because the garret phenolic one's let go and the ball bearings are made of nitrate and bores the oil feed to his own specs
Can't get into tuner before the 30th so literally I'll call on the 30th to book and go from there
  • Like 1
Does he realise there are three oil restrictors in the sump? I can tell you there isn't much oil supply at the turbo...
I did mention it several time's, it's just what he does as a standard for his Highflow service. Does the same for rb's
Rb don't have the same restrictors setup as vq's do.
It is in the line in an rb, easily replaced.
I was under the impression that on the vq25 with a bush bearing scotty drilled out the banjo's?
This one is ball bearing and getting new braided line's, I would think that should do it?
Edited by red_spider
How much is this costing you? Pm me if you like.
Perth based.
Best thing to do would be to contact grant directly. But it was cheaper than what a lot cheaper than the other places offering a similar service/product
I'll have results in a few weeks once I can put it on and get it tuned
For the info on the wheel and thrust load. He was busy when I picked the turbo up and a mutual friend dropped in so don't have the answers . he has the wheels he uses on his Facebook Page and the ball bearings and cages too
That would depend how much oil the ceramic bearings require, even with the braided line the oil will only dribble out the turbo end of the hose...
The best course of action would be to open up the three in the sump to around 4mm or so; then drill the final external (on the side of the block) to perhaps 0.5mm dia over whatever Grant specifies for the turbo feed.
That way you'll always have more than enough supply; but the braided line isn't running full system pressure. Then your braided line isn't the "weakest link" in the system.
  • Like 1
That way you'll always have More than enough supply; but the braided line isn't running full system pressure. Then your braided line isn't the "weakest link" in the system.
That's kinda what I was thinking along the lines of :) is why I called you the other day :P
  • Like 1
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
