Ok here is the deal:
I live in Sweden and have a 33 4dr that i currently building a 30/26 with about 550-600whp on E85, so with that said i allready have a high power RB in progress.
But i've also have a Nissan 180zx, or as you call them silvia s12 and gazelle, currently with a ca18et sitting in it.
The thing is that i have a rb25det sitting in the garage, and have got my hands on a NA head with cams and NA pistons.
I have a thing for NA engines and thinking about swaping the pistons and head on my 25 and going for a
NA build, i also have a set of 26 ITB's laying in the garage.
The big question is how much have been taking out of the 25na's? Im talking with cams, ITB's, etc.
When im looking at the dyno page i see mostley stock engines with pod filter and exhust, not fully built engines with cams etc.
Is there someone who have dynoed about 250whp out of a 25de ? In Sweden the BMW m50b25 engines is fairly popular and making Good power with fairly small mods.
Im well aware of the costs of a NA build and im doing it for the sound and soul of the engine, not for high power build, i just want to know best options on cams etc and best way to make 220-250 whp ish.
My basic setup in my head would be:
*25det rods
*25de pistons
*decked 25de head
*25de cams regrind or larger det cams
*rb26 ITB's
*custom exhaust manifold
*aftermarket ecu
When does the stock valves come in to restriction? Etc..
The car will recive a s13 rear subframe so i can get a 4.3 or 4.6 final gear for it, and i will roll on 195/45/15 so it's no wide tyres it will need to spin, the car will act as a street drifter so i want the nice NA sound and a fun powerband.
Any Good links to "high power 25de builds" and info would be appreciated.
//Jesse
https://www.sau.com.au/forums/topic/448280-how-much-is-the-25de-capable-of/
There isn't much out there, especially on this forum. How would you go about fitting the RB26 ITBs on the RB25 head? I know there are adapter plates available but not so easy to find any fairly expensive.
I'm sorry my reply wasn't helpful.
  • 4 weeks later...
The closest I could think of is Greg_R31's old build which was an NA 26/30. Was work of art. one of his posts said power wise was: 225hp/ 167.8kw at 8200rpm that was back in '11, can't remember if it went up from there. I'm pretty sure he sold it since then but thats the closest I could think to what you are asking.
Anyway have a read of his build thread. Had ITB's too. http://www.sau.com.au/forums/topic/374496-gerg-r31s-na-rb2630de/
As for stock valves becoming a restriction my unopened 25DE+T is still putting out nearly 300rwkw on stock pistons/rods/head. Hope that helps, good luck with the build.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
