POwer FC Boost controller for sale(R33 GTR or R32 GTR) I am after $250 for the lot.
6 * nismo 600c injector for RB26 or 2JZ = $700
Happy to COD anywhere or send it oversea but i require some deposit before i send out COD.
Let me know if you are interest on [email protected] or 0418 388 125.
Thanks
Calvin
https://www.sau.com.au/forums/topic/44904-power-fc-nismo-injector/
i am very instrested in the injectors, how many k's have they done? what type of condition are they in? any known issues? i just cant afford to have problems if i buy them thats all. Thanks
sounds good to me, so i am guessing they are nismo? in the first add you have cnismo unless there is something i am missing lol, not like scony or something , is there any room for negotiation or are the prices firm?
riteo then sounds good to me, where abouts are you? what would postage cost to toowoomba QLD, don't think it could be to much, and what are your preffered payment options?
