Driving The Car Hard After Long Periods Bad? (Track Days Etc..)
Nulon 1040 I've been using it for years on a mildly modded r33 ,do 30000 plus a year.No lifter noise on start up and engine purrs like a kitten on cruise but when you need to punch it no prob with oil pressure. :-)
Yea i heard nulon make good oil blends! I had 5 liters of 10w40 castrol edge, so thought i may as well use that for now.
Just an update, have finally gotten around to flushing out the old oil and chucking in some fresh oil, actually did it for the first time in my life, and i gotta say, oil looked like crap. It was pitch black and gross, smelt like sh** as well.
Chucked in 4.75 liters of castrol edge 10w-40, went for a drive, no oil pressure light! But it was a short drive, ill need to actually give it a good run and see if it starts to flicker again. As for the gauges, they are still getting shipped, should have it by next week hopefully :)
Ill see how everything goes, im still going to get the new pressure sender. As one of you already suggested, looking at the evo forums, found out that apparently oil pressure senders do give out on around 40k miles, hopefully thats where my problem is!
Cheers for all the help!
OH and also, thinking of going e85? 400 Lph walbro fuel pump and 1000cc injectors is on the list for e85 compatibility, but was wondering if i should get cams done as well before tuning for e85? Ive heard that its better to get cam gears and valve springs as well, but thats where it goes a little out of budget for me.... opinions?
Yea gave it a boot, still too thin ==' will definitely go 50 weight now, might also be cause its quite hot weather.
Do Evos run stock oil coolers? Maybe upgrade to something better or if you dont have one then get one installed. Will obviously cool the oil and maintain viscosity but will allow you to add that little bit extra oil which could help with the oil pressure issue, especially with high speed cornering etc.
Cheers
Amir
Cheers
Amir
Yea they do man, ill look into it further, because my mates evo 7 doesnt seem to have this kind of problem, exact same car. Im also thinking the idle is too low? should be idling at 1000 not 600rpm, maybe thats why it loses pressure on idle.
Are they supposed to idle at 1000? That seems a bit high but im no evo (or any other car) expert. See how you go man, maybe a bigger/better aftermarket oil cooler will help with some of the issues.
Let us know what happens
Amir
Amir
Umm yea most evos idle around 800-1000 pretty sure. They have a very wide rpm range, rev up to 7600ish from factory. But yea man will do! Cheers :)
Oh one more question, does anyone know a good place to get my oil pressure, and oil temperature gauges installed? I would do it myself but it looks way more complicated than my boost gauge =/
I'm actually looking for the same but in Perth. I've done everything to the car myself (with the help of some mates) up till now but with this sort of stuff I prefer someone a bit more qualified and knowlegeable than me.
Did you end up buying gauges from egauges?
Cheers
it's not that complicated man.. just buy one of these things:
I've got an oil cooler on the skyline Johnny so I've got the sandwich plate. What else would I need and is it straight forward. Mainly I want an oil pressure gauge.
Amir
Amir
the sandwich press should have ports on it though?
Cheers
Umm i used them as a reference, most of the autometer ones werent for sale, they only had the transmission oil temperature gauges for sale :( But they were so much cheaper than bloody autobarn! Saving 150 dollars buy using egauges.
But yea i rang up a few people, auto electricians and mechanics and tuners, none of them could install them. Most auto electricians focus on generic stuff like central locking, immobilizers etc... Anyways, ended up calling revzone, who i thought solely specialized in tuning and mechanics, but do gauges as well! Minimum 60 dollars to install per gauge (for an evo) so decided to go with them. Its funny cause they were my go to mechanics for everything, but for some reason assumed they didnt do gauges :P
Hey mate, yea i thought it would be, but the oil pressure sender is located behind the engine block under the intake, right above the transfer case, its almost impossible to get too without removing strubrace, intake manifold, a whole bunch of vaccum lines etc.... So thought it'd be better to leave it to an expert.
you need this:
relocates your hard to reach oil filter & also has 2x 1/8pt ports for your gauges :)
  • Like 1
  • 3 weeks later...
^ wow just saw this now! Too late though, got it installed :)
Update:
So got the gauges installed, monitored both the temps and oil pressure, basically under normal driving the oil pressure idles at 14 psi while the temps remain below 80 degrees Celsius.
However,
Under some spirited driving, and heating 22psi of boost, the temps lie between 80 to 90 degrees celcius, sometimes a little higher (didnt push it too far), and the oil pressure on idle drops to about 10PSI, at which point the OEM factory oil pressure light starts to flicker. So basically when the oil is below 11psi on idle, the oil pressure sender light starts to flicker.
After driving normal again, temps drop all the way to 79-80 degrees celcius, and oil pressure once again idles at 14psi, with no oil pressure light.
So i narrowed it down to two options:
1. bigger oil cooler - i think the temps affect the viscosity of the oil
2. Just chuck in thicker oil? (10w-40 or 15w-50)
Is it a good idea to use 50weight for daily driving as well?
Thanks for all you help btw, helped me a lot so far :)
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
