On Sunday I took the car out and found it extremely hard to put it in 1st, literally had to use 2 hands to get it in, lucky I could get it home safely
Today I took it to work and it left me at a set of lights with no clutch pedal ! Noticed fluid was below the L line, so I topped it up and got it to work,
Now I just got home and it started playing up again, checked fluid and it's on Low again
It's not leaking inside the engine bay, and it's not leaking where the clutch pedal is either
Slave is a nismo unit looks dry and not to be leaking ?
Anyone have any ideas what it could be or what to check ? When I topped it up the clutch pedal/shift was perfect
Could it leaking past the master cylinder and into the booster ?
https://www.sau.com.au/forums/topic/449680-loosing-clutch-fluid-from-somewhere/
Yes well.....given that it's a GTR and therefore has a clutch booster, it won't leak back into the cabin until it has filled the booster and wrecked the seal on the firewall side of it. So that will be where the fluid is. Rip it off, take it to be kitted. Pronto.
The rubber clutch hose on my car split and caused the pedal to die, although a lot quicker than yours. Maybe check that out if you want.
I replaced it with a braided hose, bypassing the standard block thing underneath the driver's floor. Not sure what it that did.
In r32 gts-t (not sure if Gtr are the same) they have a clutch cooling loop. Same principle as power steering cooling loop in front of your air con condenser. It's pretty rubbish and makes it difficult to bleed. I ditched mine in favour of a braided line straight from master to slave.
Yep, same on my GT-R (did the same thing).
I did find that it was slightly "nicer" to press the clutch with the standard crap in. But I have a very heavy clutch. Matter of time before the clutch bracket snaps...
Figured it was more of a damper design than a cooling loop. Oh well, weight saving :P.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
