For sale
Greddy suction kit for rb26
Suit stock afms
good condition
$950
Pro sport strut brace for bnr32
$80
Arc bov and adapter pipe
$100
Stock bnr32 turbos
Minimal shaft play
$200 for both
Stock bnr32 cam gears
$50
Stock bnr32 dump pipes
$50
Stock smic r32 gtst
And pipe
$50
Inner guard plastics r32 gtst
$80
R32 gtst power window mech
$50
Asorted box of stuff, everything in the pic
$50
Located western sydney
Call/text 0425896150
post-121965-14141019645232_thumb.jpgpost-121965-14141019844709_thumb.jpgpost-121965-14141020000342_thumb.jpgpost-121965-14141020195531_thumb.jpgpost-121965-14141020330297_thumb.jpgpost-121965-14141020450704_thumb.jpgpost-121965-14141021386557_thumb.jpgpost-121965-14141021529527_thumb.jpg
https://www.sau.com.au/forums/topic/449991-r32-gtr-and-gtst-parts/
For Sale
3.5 inch cat back
Stainless steel Exhaust
With adjustable muffler
Nice and quiet when shut
Nice and loud when open
Good note to it
Keeps whingy neighbours away
Suits bnr32
In good working condition!
$300
Price revision
Stock bnr32 clutch fan
$70
$70
$80
Stock bnr32 turbos
Minimal shaft play
$180 for both
$40
$40
Stock smic r32 gtst
And pipe
$40
$40
$40
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
