I still don't understand why? Lol they are only +1mm, not like its 2 Or 3mm. When clearly the aftermarket cams are 30mm base standard is 32mm.
So you don't keep throwing shims running smaller base circle cams. With the tomei buckets you use standard size shims, do the math mentioned above.
Or you could look for a one piece bucket and shim which, if it exists, would be at least as much as tomei plus you'd almost be guaranteed to have to buy a few more when a couple of the clearances end up being a little out. Subaru do this with the later ej's- makes redoing seats/refacing valves much more expensive.
Edited by doo doo
I believe there is a company in the US that make one pieces for Toyota UZ engines after not liking the standard shim over or shim under setup. Was ages ago I was reading it but may be worth investigating see if they made any for RB's.
Shimless is obviously the best way to go if you can sort it out.
Anyone running that kind of setup, what is standard practice for a head rebuild if required? I assume you need to grind the tips of the valves or top of bucket in order to reset lash after a valve/valve seat regrind?
If it was possible, which I don't think it is with standard valve lengths is using lash caps instead of shims. Far harder to flick a lash cap then it is a shim. But I don't think there is enough valve tip protrusion above the retainer on a std setup in order to utilise a cap.
  • 5 months later...
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
