Is there any united e85 nearby ?
I asked that question and was quite rudely told to try google
To save the hassle for anyone else, no there is no E85 at singleton, it is BYO
I am taking 3 x 20l and a 10l Jerrys with me just in case as are a few others
  • Like 2
From my previous visits I did not notice any E85 at the petrol stations.
They do though have a range of petrol stations including Shell, BP and Caltex.
Sorry to hear you will be missing this Sam.
Hopefully everything will be sorted out with the car quickly!
  • Like 1
bleh , was thinking of coming but maybe not , don't like the ideal of carrying so much petrol around guess there's always next time !
There's no E85 in Singleton itself but i imagine there would be somewhere close to the south end of the putty people could fill up at? Im not sure of the distance to singleton and back and how far a full tank gets you but maybe it would be enough up and back?
Ok for the E85 people here is the best info I could find.
Singleton does not have E85. The best options so far are:
Richmond Caltex which has EFlex and is 17.2km (17 minutes) from our start point or
United North Richmond which has E85 and is 13.3km (17 minutes) from our start point
A full tank of E85 gets me around 420km of day to day use but we'll probably burn a little more if we give them a (legal) squirt every now and then.
The cruise total length is approx 177km which means theoretically it's possibly to do this cruise on a single tank of E85. If you don't want to run the risk then 1 Jerry can of fuel SHOULD suffice. You could even organise with someone who is bringing jerry cans with them to bring one along for you and pay them for it if they are willing.
*All of these figures are approximations based on googles assessment of the route without taking into account traffic, enthusiastic driving etc, and my experience of E85 on my R34 gtt, and I will not be held accountable for anyone that runs out of fuel by using the above information*
I hope that will help clear any confusion. I plan to just do the cruise and chuck some 98 in if I'm desperate as I have a full flex fuel tune :)
  • Like 1
I believe there is United E85 at Cessnock. So I am planning on filling up there so I can make it back home again after the cruise.
I did a search at that end but it said there was no United at Cessnock but that certainly doesn't mean there isn't one just that it's not online
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
