Went to fill up this morning, and the E-Flex pumps were taped off. Spoke to the guy behind the counter and he said that Caltex are no longer bringing in stock of E85. He said that a couple of servo's still have a few weeks' stock, and then that's it.
Anyone else heard this news? He suggested partitioning Caltex to keep E85 in SA.
So if this is true... then the only place left is United. For me, the closest is probably the Adelaide airport station (which I hope is 24 hours... might not be). Unfortunately, my tuner says the United mix is higher ethanol content (about E80-E85 compared to Caltex E60-E70 ish). This is good for power, but probably means a retune. Or a calculated mix with some added '98.
Nistune do flex-fuel sensors now, but that looks like costing another $2,500-3000 because a lot of re-tuning is required.
Anybody else running E85?
https://www.sau.com.au/forums/topic/450598-no-more-caltex-e85-e-flex-in-sa/
I thought there was one closer to me but I was wrong....
Caltex down Seaford way does not,nor did it ever as far as i know, stock E85.
Not sure of the nearest United to me but it is very annoying not to have the option :angry:
Haven't seen any E85 at the united's down south, being Adelaide it wouldn't surprise me if the airport was the closest one.
The airport one is 24h (or was...)
  • Like 1
At least it's 24 hours but yeah, 20 minutes for me too. Trouble for me is that my stagea is tuned for E85. I've got a '98 map but it's only for low boost, and there's a bit of messing around required to get it on the ECU because my consult port is on the blink at the moment.
I think I also need to get a retune to use the United E85 since it's properly 80-85% instead of about 60% (E-Flex) which my tune was done on.
Just add the approximate percentage of petrol and you will be fine, err on the side of rich and you will be more than safe enough. (your cold start will probably improve :P)
A wideband is a good idea for these situations, my new WB kit only cost $130us...
Shame the Caltex boffins are shutting it down, but I guess it just isn't viable for them now that United are in on it.
I had considered doing my own in-tank mix of 98 and E85 too... when you say to err on the side of "rich", do you mean err on the side of more 98 (lower % ethanol) or more E85 (higher % ethanol)?
The issue I think with the United E85 is too much ethanol means it will effectively lean out, as the burn ratio would actually call for more fuel, so I need to add some 98 to reduce the overall ethanol percentage probably to about 75% (to be safe)?
By my rough calculations (I'm terrible at maths), if 51 litres (ethanol content) / 60 litres (rough tank capacity) = 85% (united mix), then 45L / 60L = 75%... so I add about 6 litres of 98 and then fill the rest with E85.
Sound OK?
I think a wideband O2 sensor sounds like a good idea, and Nistune supports that now (although I'm mainly worried about the high load/max boost/max revs type scenarios). Where have you got your sensor installed, is it mounted permanently?
6L would be ok. I used to add that much anyway in winter just to help with chilly cold starts. 10L of 98 would work fine too. It isn't too critical, ethanol gives you a fair safety margin, and the chance you will foul plugs is minimal.
The wideband is standalone, you don't need to plug it into the Nistune. I use mine for road tuning and to make sure the mixtures are ok.
  • Like 1
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
