Hi guys,
New to the forum. Picked up my first V35 350gt(2003 Coupe 6mt Bone stock) in Australia last week (Had an Infinity G35 in States). Absolutely love the car, mechanically it is immaculate, drive and shift smooth.
Today I notice an issue with Climate control. When i adjusted air con temperature from 18 to 28, i could barely feel any change, air was really cold all the time. Until i set it to 29, I could finally feel a bit difference. When i set it to 32, vents started blowing warm air but it was moderate. Also I notice that once AC is on, the compressor will not kick off, it stays on all the time unless ac off. I thought , compressor should switch on and off to adjust temperature.
Any thoughts? Please help, thank you!
https://www.sau.com.au/forums/topic/450604-ac-temperature-issue/
These cars use a variable displacement compressor, they don't regulate temperature by turning the compressor on/off, the cooling power is adjusted by varying the compressor displacement. A bit like an inverter air conditioner for a house. So the compressor is always engaged when the AC is turned on.
That said, i have found most car ACs with climate control will turn on the AC compressor for at least the first 5 minutes after switching it on, regardless of the temperature setting. Probably for situations where you are using the AC to dry the air (defog windows) rather than just for cooling, usually the system will engage the heater at the same time.
Also keep in mind, CC systems usually have some 'smarts' built in, they monitor the external air temperature, and detect sunload, so they may blow cold air, even if the interior cabin temperature is at or below the current set point, in anticipation of the heating effects of outside air and sun. They don't wait for the cabin to get hot before reacting.
Thanx for the response, Sonicii. Hummm, that's really interesting. anyway i did check the cabin air sensor underneath the steering wheel, it all hooked up. BTW, how do you monitor the reading from interior temp sensor?
I don't think you can in normal operation, but I believe you can go into the diag mode and see what temperature it is reading from the sensors.
I have attached the page from the FSM which may help.
atc.pdf
Edited by sonicii
Appreciated! Had a check, all three temperature sensors work fine.
Hi, I did check all three sensors again closely, when i ran test 2, it displayed 20 which i believe means all sensors are functional. But when i ran test 51, outside temperature sensor reading is 44(Actual temp is around 33), Cabin temp reading is around 36(Actual around 30 inside), MAF temp is around 26. Since outside temp is always displayed on center console, i found after a quick drive the out temp dropped from 44 to 34. However once I start the self diagnose again, the readings are inaccurate again. Is this means something wrong with the outside sensor and cabin sensor?
the outside sensor will be impacted by engine heat when you stop.. it is mounted in front of the radiator, which is why you see it drop fairly quickly once you start driving again.
Cabin temp sensor is near your left knee when in the driver seat, so you would need to ensure you are checking the temperature from around the same area.
It is unusual for these items to be inaccurate, normally when the sensor fails.. it fails properly..
This may not be your problem but worth a quick look!1
I had either really cold at 18 degrees but even on 18.5 onwards the temperature was blowing hot air... After further investigation
the sensor 2 pin connector under the steering wheel had bent one of the pins hence not working the sensor properly...
Check the connector pins and make sure they are not bent.... Once I reshaped my pins the climate worked fine!! Cheap fix..
worth a look hey!! good look....
No power to my AC at now at all. im stumped... ;-(
Good luck !!!!
Good luck !!!!
Sorry to hear that your ac not work. Anyway thanx for the hint, I will look into it.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
