Hi guys,
Trying to change my brake pads. Its a surprise how fast the car munched through these. Anyway, I cannot get the pistons to squeeze back into the caliper to fit the new pads in. With that said, I've also got a new set of rotors to go on the front too which is just gonna make things even more challenging.
I've got someone to crack the bleeder as I applied pressure using a screwdriver against the piston which didn't help. My old method was to use clamps to squeeze the old pad down the middle to evenly push both pistons back in. No dice. They won't budge.
Any ideas? Will cleaning then with brake cleaner help? Any special tools to do this? Everything I've found is designed for those brakes which are different to skylines, they only have pistons on one side.
https://www.sau.com.au/forums/topic/451089-cannot-rewind-brake-pistons/
that usually means its time to get the caliper serviced, look for uneven pad wear to see if your calipers need to be serviced
my backyard way of dealing with the stubborn ones is this
  • clean it first,
  • then put the old pads back on the caliper,
  • put the caliper back on the hub, do the bolts up,
  • then stick a pole in between the pads (the one for the jack) and leverage off that to force the pistons to open up..
the old pads will protect the pistons and seal from damage
make sure you open the lid for the master cylinder to make things a bit easier
obviously this won't work with single piston rear brakes with the calipers acting as hand brake as well, I've only ever done this with opposing piston calipers
that's my 2c
Edited by chiksluvit
First things first, undo the lid on the brake master. Someone who isn't me spent a while trying to get their pistons back inside the caliper to no avail, only to realize that he had not undone the filler cap. As soon as he undid it and gave them another shot they slid back into their position easily.
Also get yourself a large pair of multigrips. They make life a lot easier.
Use a g clamp or a proper piston push back tool.
Sounds like rust or dirt on the pistons or they are going in at an angle and stuck.
The last time i had a difficult piston, i dissembled it and found it was rusting in the caliper bore, changed the piston and seals and all was good.
Rear calipers?
Do the pistons have a pair of slots in the face (like a big cross)?
If yes to above, put a big fat screwdriver into the slot and screw the pistons in like a big fkoff screw. This is part of the park brake adjuster mechanism.
Note I see you have an R33 with twin piston calipers, so they probably have the drum style park brake. In that case, the above won't be applicable (it works on R31's though)
Yep S2000 rear wind back, yes have a cross in the middle of the piston to drive them back with and for the pads pin to lock into, R32, R33 and R32 have the handbrake in the drum part of the rear discs so its a straight push backwards, pistons are flush with no cross.
Usually the windback type calipers are the ones with the handbrake working the pads in the caliper, not from a seperate pair of shoes inside the discs drum section.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
