Actually they have improved the roads now. Kings Hwy (thanks to foreign relationship) is very very good now, I've been told.
Although this beast only runs in the airstrip. Its on E85, which is imported privately. Country's only R35 runs on local 91 + octane booster. Surprisingly runs ok!
Okay back to topic, thread needs more Evo guyss..
http://i1229.photobucket.com/albums/ee463/mick_o1/20130818_132850_zps1324c240.jpg
Heres my 9 stock block FP green turbo,Cosworth M2 cams, toxic fab manifold, Link G4 ecu, spoolin up COP, ohlins coilovers whiteline sway bars, carbing airbox, custom intake and short route intercooler pipework, flex fuel sensor, DBA 4000 T3 rotors QFM A1RMS pads Hel braided lines & probably more that i can't think of lol. When tuned should go around 320kw on E85 & Around 270kw on 98.
  • Like 1
Haha of course of course, evo demolishing corners is standard :P i was curious considering that is a lot of power !
A good all rounder evo you have there.
Judging by the vid and mods done to this evo, id say 11.7ish in your car
  • 4 weeks later...
Nice and stealth Rob :)
Whats the 6262 like on the 4G response wise?
Wasn't too bad at all, lag was noticeable but i had full boost around 4500rpms as long as you stayed in the higher rpm range it was great.. had an issue with my 38mm external gate and stepped it up to a 44mm later on and had no issues... 4G63 motor is my favorite 4cyl definately over the EJ20's and EJ2.5's
  • 3 weeks later...
Developed some shaft play, even though It was freshly reconditioned before it was sold to me, only been on the car for about 6 months :(
Luckily it's still under warranty but in saying that, it's only covered dependant on the cause of failure.
Should see some good results with the 712, very responsive turbo!
I was opting to get that or the red/green. But decided on the red, simply cause I had plans to do a stroker build in the future.
On a 2L, it's not really fun driving on the street, full boost at ~4300ish :down:
I'm selling a precision 6466 with JMF 1.5" runner ceramic coated manifold and turbosmart 45mm pro gate. Good for comfortable 500kw.
Downsizing for response to BW EFR7670, twin scroll, twin gates.
Any predictions for boost threshold on a 2.3 stroker, +1mm intake and exhaust valves and kelford 280s? I know the cams aren't ideal for response but couldn't be bothered changing them.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
