Well i got my car back from getting compliance done on friday but licensing centers where shut fri/sat/sun/mon so tomorrow is the day :(
Just wondering, I just read on there website that for import cars you need to make a appointment, just wondering if you have to do this or not?
also what details do i have to give them?
BTW its a R33
cheers
https://www.sau.com.au/forums/topic/45125-licensing-car/
well went there today line was out the door, waited over a hour for the inspection fee, then a hour in the pit area, finally it was my turn he said wheres ur import approval. I didnt think i needed one but i didnt know and he said i needed to make a appointment :( this was 3:45 so i think he wanted to go home,
but i rang up autoworx they did my compliance and he said you dont need the import approval, so im not a happy man now :P
so made appointment for 9am tomorrow hope it goes all ok this time grrrrr :D
https://www.sau.com.au/forums/topic/45125-licensing-car/#findComment-922175
cheers
umm raistlin is i dont know really ahahha me and mate used to use it and i think he said it was a king in a fairy tale book or somethink
pretty crap but couldnt think of any think else to use
oh well hopefully tomorrow can finally go for a nice drive it in
https://www.sau.com.au/forums/topic/45125-licensing-car/#findComment-922192
well i got a exhaust on has 3" front pipe and 3" cat back
the car is standard but its empty and didnt change the dump pipe
got it on the dyno and its running 10psi now
and got 228.7rwhp
if i put a 3" high flow cat and a 3" dump pipe would the power go up much more or not?
cheers
https://www.sau.com.au/forums/topic/45125-licensing-car/#findComment-945872
dump pipe made a lot of responce difference on my ride ive got a custom dump 3" mandrel bent high flow cat and supercat muffler havent dynoed put felt heaps quicker the dump was customed to open up the waste gate all the premades i saw conected to the original cast manifold leaving the waste blocked still so for an extra 150 i went for custom
https://www.sau.com.au/forums/topic/45125-licensing-car/#findComment-946392
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
