Hey everyone, I'm selling some gear off my GTR that is now running a singe turbo, E-flex and other gear, so all this stuff is of no use to me.
3" MINES front pipe, great condition, needs a clean - $700
F1806071-0172-4295-87FC-56E91E13E46F_zps
5EFA2E1B-E0EC-4127-8C87-5BBD4CADA629_zps
R33 Greddy dual gauge pillar holder - $150
9CB567E1-0076-4330-B50E-07BB5C169316_zps
Cool, old school, period correct Greddy 2bar boost gauge - $150
80305050-3D27-41AB-904E-388CFDE722B0_zps
R33 GTR door speaker covers, cut out of speakers - $50
EA2123FF-31BB-42A9-ADB6-C97DB2B317E7_zps
R33 GTR V-spec turbos, no shaft play that I can see. These were pulled off the car two months ago, I never owned the car when they were on, but they were making around 260hp at all four on stock boost I THINK***. I'll include stock manifolds and dumps if you want them, buyers welcome to purchase manifolds separately. $500
6BD29CA8-C5A3-4DC2-AAFF-DAFC425681D3_zps
2551E8BB-503F-4CE9-A1F1-21770EA52AFF_zps
R33 GTR MINES ECU (my car is an ex MINES car, lots of MINES goodies on it) - $250
4BD8E40F-37FE-44D7-89A5-609656909AE3_zps
R33 GTR intake pipe work (not including AFM's or intakes with pods in this) $200
606CF15B-F773-4E68-A6A4-2049F23A4E93_zps
MINES AFM's, similar resolution to Z32's, very nice condition, shiny MINES badges, rare - $300
FEAB54B5-8713-41EC-AA38-33506CEFEC04_zps
Pickup available in BRISBANE, shipping available at buyers expense.
Text me (Trent) on 0401029817
Luke, I can't get a quote off the top of my head for it, but the entire intake would be under 30 bucks easy if I boxed it up.
MINES AFM's sold.
MINES Front pipe sold.
Sorry for the late reply, Luke. I haven't checked the forum for a few days.
If anyone wants me, 0401029817 is the easiest place to get me.
  • 5 weeks later...
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
