I remember reading somewhere that there were a couple variants of the HKS GT2530's as well as the KAI model. I'm assuming this means HKS updated them along the way, does anyone know if this is true and if so what are the difference and how could each be identified?
Any info would be greatly appreciated
https://www.sau.com.au/forums/topic/451492-hks-gt2530-variants/
all share the same CHRA/wheels except the kai.
Housings differed like mentioned.
RB26 housings also differed mainly on exh side, early had no splitter late had a splitter on the outlet that was flush to the outlet flange. Apart from that some minor gate differences
No real power difference if your using a 1-1.5'' wastegate separator in a bellmouth
They should all be using the same cartridge and wheels 446179-21 from memory . I seem to remember the KAI version having a port shrouded compressor housing so was likely a single turbo version . The main unique part today is the 60mm 63T compressor wheel and I think it was only ever used in 2530s and one other app I can't remember .
You can turn any GT2860 with the same turbine into a 2530 if you have the original undamaged compressor wheel and housing . Swap the wheel in balance and bingo new guts .
A .
why do you ask? perhaps if we had a bit more info on the specifics of what ur trying to find out it would help...
I'm gathering parts for a turbo upgrade. I'll be looking for roughly a safe 320rwkw but more power down the track so I'd like to get the right turbos from now, hence why I'm looking at the 2530's. I know -7's or even -9's would be better suited to that 300+ mark but any more power later on will be maxing them out. So I guess at the moment I'm just trying to educate myself on my options.
Just get the -9s.
Sell the -9s if you ever decide to go for 400rwkw and get 2530s in 2/3/4 years (or more) and enjoy the -9s for their application for now because realistically 2530s is motor out/rebuild time anyway. So changing turbos isn't a big expense.
  • Like 1
Might also depend on your demographic, i.e Sydney lots of 40/50klm zones and not much
in the way of over 80klm higher load gears, a few hundred rpm of boost threshold and
less off boost power can make driving around on bigger turbos tedious.
The opposite if you live in an area with lots of open roads or highways. I.e rural or
the US. You can get away with larger turbos since you are mostly above 80klms with
very little time spent in stop start traffic and low speed pot holed filled corners,
stupid 40klm school zones with not a single kid in sight. In this case you can go
for the -5 or 2530's and just not spend enough time off the boil to care.
End of the day, it still comes down to drivability first as the main consideration
on size, then peak power goals.
I will tell you my experience. I had a unopened motor with -5's and they were a little laggy (running 345kw atw) but on the open road they are great. In the city not to much (as above).
When I rebuilt the motor and did head work now pushing 400kw the -5's have come alive. Still running 2.6L and they are more than fun anywhere haha. I wouldn't waste money getting 2 different sets of turbos (selling one for a loss later) if you plan to rebuild. Go for a set you want to keep deal with the lag at first then benefit later when you rebuild. Less cost when you do rebuild.
Also as Jeremy Clarkson said - lag can be fun at the lights when people think they are winning then they wonder where you have gone.
Yeah I do see where you're coming from but would the -9s be that much better than the 2530s for my goal that you can justify doing it twice?
Absolutely. Turbos are the most important thing to choose. They decide everything in a set-up in a stock-ish scenario.
You are talking about $1,200 or so. So like I said if you plan on not rebuilding etc for 2 years or more - then change it out when the time comes.
I've had both -9, -5s and modified -9s... The -5s around town, hill runs, motorkhana etc as stated, are tedious on a 2.6l. -9s win for a car doing that type of work hands down.
-5s come into their own above 120km/h-150km/h+. You just gotta ask yourself how much time are you spending above that? And go from there.
Would HKS GT-SS's be an even better option?
Thanks for all the help guys
Much more research needed. The Garrett -9s and HKS GT-SS are the same turbo, just a different branding. HKS "kit" just comes with everything you need to bolt on, oh and a much higher price tag.
For my project the motor will be just one aspect in a sort of complete rebuild with suspension next and ultimately paint and interior so I think what ever set up I go for now will pretty much be it for a while (providing the motor doesn't give up). Having said that though I do miss the punch my 33 GTST used to give so maybe that little bit of lag given by the -5 will be enjoyable but I definitely don't want to have to go 120km+ whilst ringing it's nuts for the turbos to show what they've got. My best bet would be to experience most, if not all of my options first hand.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
