All you detailing gurus out there, I need some advice.
I am being plagued by streaking wax, only on my bonnet.
I have searched and searched and they say it's either contaminants on the paint or not letting the wax cure long enough.
Now It doesn't matter if I let it cure 30 min 1 hour 2 hour even went as far as leaving it for 4 hours. Nothing makes a difference to it streaking.
Today I clayed and polished the bonnet with RO. Used a brand New pad for waxing (thought maybe a old pad was causing my issues) alas nil change. I have tried multiple waxes and nothing changes.
I have tried every speed setting on my RO with no result.
The only way I am getting around it is by using a damp cloth afterwards and even then it is some elbow grease and repetition to remove it.
FML midnight purple.
Any advice?
https://www.sau.com.au/forums/topic/451675-streaking-wax/
What kind of wax are you using mate? I'm guessing a liquid based synthetic polymer? Are you using a fairly slow speed setting on your machine?
When you say streaking do you mean it is difficult to remove in some areas or do you mean once you buff it off you are noticing streaks our in the sun?
Sorry for all the questions just trying to narrow down the issue :)
https://www.sau.com.au/forums/topic/451675-streaking-wax/#findComment-7443181
I have tried every speed setting. Usually I go for a slower speed and do 2 overlapping passes.
It is easy to remove the film of wax. It is not the white residue I am speaking of.
Once the wax is removed you can see the darker streaks on the paint which can be manipulated by a cloth.
I have tried synthetic, carnauba hydrophobic polymers the lot
https://www.sau.com.au/forums/topic/451675-streaking-wax/#findComment-7443187
Maybe something leftover on the paint after polishing? Like polishing oils. Try IPA or wax/grease remover after polishing but before wax application. Or add a glaze in between. Personally i use Dodo Juice Lime Prime light after polishing to prep for wax
Edited by junkie
https://www.sau.com.au/forums/topic/451675-streaking-wax/#findComment-7443380
wax your car in the sun.
I apply with a megs applicator pad by hand.....or with my own bare hands.
that is the best way to applicate, I avoid machines for waxing.
I use the straight line technique to apply then buff off with a microfiber towel in circles.
I do not get streaks doing it this way.
https://www.sau.com.au/forums/topic/451675-streaking-wax/#findComment-7443832
Having read what you have said, it now sounds like maybe using to much product? Especially when using a good quality high carnauba content wax (such as Dodo Juice, Swissvax etc.) you only need very small amounts and personally I would always apply them by hand as opposed to a machine as you are not needing pressure and heat to help you. Always ensure the panels are cool and never do it in the sun with carnauba waxes. You can only get away with doing it in the sun with synthetic polymers but even then I still wouldn't do it as panel temps can get over 60 degrees.
If you can easily manipulate the streaks just use a few different soft microfiber cloths (using good quality MF cloths is especially important here as cheapies will make the job much harder) and keep gently wiping away until all the residue is gone.
But it does sound to me like maybe using to much product so maybe give that a go. Also another thing to think about is with a lot of waxes once they are cured and removed, they are hydroscopic for the first 12-24 hours so avoid getting the car wet and they may leave a slight haze during this period due to absorbing moisture from the air (an annoying issue for me in such a high humidity climate of NQ).
https://www.sau.com.au/forums/topic/451675-streaking-wax/#findComment-7446593
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
