Hi, I just had my stagea dyno'd with an adaptronic 440 running in tandem with the stock ECU.
I didn't have any trouble with the stock ECU while doing preliminary drives on the base map, but while on the dyno, the tachometer stopped working, the synchro, 4wd and abs lights came on.
While the tachometer has stayed totally dead, the other lights would come on when you start the car, but sometimes go away after 10 mins or so.
While the lights were on, you could feel the transfer case locking up. The wheels and drivetrain would slip and grind while turning sharply at low speed. That went away once the lights had also gone.
I checked all the fuses and found that the 7.5 amp "ECU" fuse had blown under the drivers side coin tray. I replaced it with another, which has not blown yet, however it has not solved anything.
Now the more crazy stuff. Due to the transfer case locking up, I removed the 4WD fuse and relay in the engine bay, as per the photos.
However the warning lights were still on and the transfer case still was still locked up! How is that possible? What is actually powering the attessa pump?
I am thinking I should remove the front driveshaft to avoid further damage.
By the way the only code I an pull up is code 21 - injector signal. Im not sure if thats related as I dont have injectors connected to the stock ECU, only the adaptronic.
Im not sure how to check any other codes, like gear box or attessa?
just thinking out load
can only think the adaptronic 440 is messing with the ECU signal to the gearbox ECU
gearbox cant handle the power and has gone into limp mode ?
your description of " slip and grind while turning sharply at low speed" sounds like the diff lock was engaged ( button on dash )
i have fitted a nistuned S2 ECU in my S1 and it worked the gears ONCE and then nothing , only third gear
not sure i helped but maybe it has jogged something :)
It is like having the synchro button on, with the light and the low speed clunking. However the position of the synchro button doesnt make a difference.
The auto gearbox seems to be functioning normally as far as I can tell.
Does the attessa system have its own computer and such? I remember something behind the carpet at the rear of the wagon on the passenger side. Opposite side to the reservoir tank.
Just bumping this. I have put my head in through the passenger side flap in the boot to try and see any flashes of light. I tried this with the ignition in the on position, and straight after starting, but could not see any lights.
I have read that the car needs to be driven over 30kmh for a minute to bring up error codes, even though the warning lights are on the dash as soon as the car is started. Can anyone confirm this?
Where exactly is the flashing LED? I poked around with a mirror looking for a light on the computer, but all I could find was a small hole in the computer approximately on the bottom right of the unit, if you are looking at it from inside the boot.
Edited by zoomzoom
I have an instrument cluster that is always full of petrol,runs hot, speedo does not work and only does about 400 revs. All the warning lights work fine.
Y?
Well, theres definitely no lights coming from the attesa computer in the back. I can't even see the "port" where the light would be that people have referred to (mainly on r32s though)
Tried manually bridging the 4WD relay in the engine bay to hear if anything worked. Strangely the synchro light went out!
Also, I did an ECU scan through OBD scan tech. It can only detect 3 computers: engine, auto trans and airbag.
I now have NFI how to read any codes from the attesa.
Woohoo, well a long story short, the ATTESA requires an RPM signal (along with a TPS signal, but that was functioning)
It seems both the tacho pin on the stock ECU is non-functional, and also appears as though the tacho itself is faulty.
Its hard to tell exactly where and how the wires to the tacho and ATTESA are joined, but I fixed the 4WD by splicing a new wire from the tacho pin on the ATTESA harness to one of the aux outputs on the adaptronic which I configured as a tacho signal in WARI. The warning lights cleared straight after starting the car, and I could hear the pump priming. Such a beautiful sight.
Tach is still dead, ironically it will probably be more of a problem then the 4wd...
Edited by zoomzoom
I figure that will be the case, but I think my ECU is still faulty too. I dont think the piggyback ECU is going anywhere, maybe its time for a mad 1990's "futuristic" digital dash? Im not sure why they didn't catch on.
  • 2 months later...
Just reread your first post. It takes more than pulling the awd fuses to disengage the attessa. Were you on a 2wd or 4wd dyno?
For what its worth here is the manual on turning the Attessa off (sorry forgot I can't paste to this forum for some reason so I'll try to attach it)....
4wd to 2wd text.txt
Its all good now. The car was on a 4wd dyno, I only had a chance to diagnose what the 4wd was doing once I drove it on the road. Pulling out the fuses did disable the 4wd though? If theres no pump pressure, there should be no torque applied to the front wheels beyond the preload on the transfer case?
Anyhow, I was mainly sharing the tacho fix, I know theres a few people who have busted tachos.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
