Hey, i have just finished installing a new head gasket for the first time on this engine, i am about to install the intake plenum and air ducting, but i still have these 4 brackets left to attach, im not sure where abouts they go, and i dont want to put the plenum on before putting the brackets on, if someone could point me in the right direction that would be helpful, if possible could someone post pics?
top left and bottom right attach to the lower side of the intake plenum..
Bot right is central holding knock sensor cable and attaches to the big part of the loom
top left goes near firewall, the little notch against the plenum it should be straight forward from there
bottom left goes on the manifold as part of the heat shield.
My advice is to put the lower half on and connect what you can... If you look at the bottom half you will see all the associated holes with thread in them, they almost line themselves up when you do it all.
Looking at it again I think the top left one goes towards the front end and holds the grey injector loom plug and helps with the TPS wiring and such
Do you mean the bottom right goes towards the injector loom and tps wiring? And top left goes on the plenum? I just wanna make sure cause I think you may have meant to say bottom left instead.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
