the block, crank and rods are the same for the a6 and a8 engines, the only difference is the Pistons.
If you plan on leaving the bottom end stock you should use the a6 bottom end cause you will get a better compression ratio.
for the head, if you have a skyline I'd just use the head you have in your car
https://www.sau.com.au/forums/topic/452329-2530-questions/#findComment-7454868
The same mods for the 33 head I believe, I went with a 33 head on my build, after it was finished and the money was spent I found out that the Neo head flows better than the 33 head and has solid lifters and VCT, the VCT trumps the 26 head.
So a neo head on a 30 block is a win win win situation.
https://www.sau.com.au/forums/topic/452329-2530-questions/#findComment-7454902
To use the r33 head in your r33 you'll need the usual head modifications (weld up vct feed hole and run a line to replace it) apart from that it's a bolt on
to use a neo head in your r33 you'll also need to change the wiring harness and ecu
https://www.sau.com.au/forums/topic/452329-2530-questions/#findComment-7454903
To run the neo head in an r33 you need to swap the cas wires and vct plug.
I assume you would be using a tuneable ecu.
Ps.
I have a neo head already modded for use on an rb30 block (welded vct feed and coolant gallery built up for correct gasket seal, external vct feed line included)
Noe head gives you much better compression, along with solid lifters, less oil up in the head.
https://www.sau.com.au/forums/topic/452329-2530-questions/#findComment-7454904
Pmd re head, rather than claiming this as my for sale thread I will focus in reasons why the neo head is better.
And another reason neo is better, no silly head drain ar the front as neo vct works better.
https://www.sau.com.au/forums/topic/452329-2530-questions/#findComment-7455295
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
