Garage sale
S.E suburbs melb
Mostly RB stuff
Cleaned out the shed and found
Blitz return flow cooler
R34 or R33 $150
Skyline rb25 dump pipe $20
Skyline rb25 dump and down pipe $50
Silvia sr20 dump and down pipe $50
Rb25det gates timing belt new $40
Bkr5eix-11 iridium plugs new for skyline 3 sets $20 each
K&n panel filter to suit skyline new $30 each
X force 3" muffler $20
R34 quarter windows both for $100
R34 factory side mount $30
R34 windscreen wiper bottle $40
Nismo side mount air diverter $40
R34 factory indicators $10
R34 rear windscreen wiper motor $20
R34 factory rear bar $100
R34 factory air box snorkel $10 each
R34 factory cat $50
R34 door handles $10 each
R34 handbrake cables $10
Spread the word if you know anyone chasing any of this stuff as it will be a shame to take it to the tip when someone out there might need it
Give me a call on 0433696875 if you need pics
Cheers
https://www.sau.com.au/forums/topic/452341-garage-sale-se-suburbs-melbourne/
UGHH!!!!!!!!! I've been looking for a return flow for WEEKS :(
If he doesn't pickup let me know. I will come TONIGHT and pay cashhhhhhhhh.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
