  • 4 weeks later...
There would have to be some free power hiding in the RB26 intake. Even going to a Plazmaman top on normal RB25 runners makes 10-15kW extra without changing much else. The 26 plenum has short and fat runners, so the tuning tends towards higher power at higher revs straight up, and on top of that it will have a little less pressure drop than a 25 manifold.
  • 3 weeks later...
