Tps voltage 0.5 with ignition on still 0.5 at idle. With ignition on and accelerator floored tps voltage 4.34. Tried the crab cleaner there was no change in idle, couldn't get underneath the intake but sprayed everywhere else.
I am fresh out of ideas last thing left is for me to have a go at the exhaust cam gear. I also shot a video that I will be trying to upload for you guys to see and make your own analysis.
Edited by Daboss
  • Replies 66
I was under the impression that no-one had successfully undertaken the internal vct supply mod. I guess to be absolutely sure that it is working as it is supposed to you would have to check on a dyno. Maybe you could try a timed 80 -120 run with the vct on and off and see if there is any difference.
Advanced exhaust cam gear 6 degrees engine is a lot smoother; still can feel vibration when sitting in the car and at idle vacuum is in the 10's.
Did a wide open pull in second full boost came on at around 4700rpm out of a holset hx40 with a twin scroll t4 .58 back housing. Pulled very stringly at the onset of boost enough to spin the tires at 12psi, Still needs a tune. Does that seem laggy?
Car still does not feel right, can not control idle from pfc stays around 1000rpm and when i lower it using the hand controller the rpm rises.
do a boost leak test see if you can find a leak... open the throttle as well with a brick on the pedal and spray soapy water on everything ...then find bubbles. do you have idle air control valve? or is it all ditched?
I have idle air control valve.
The brick on pedal is while doing the boost leak test?
Cams would reduce vacuum as well right? By reduce i mean going from -17 to -10.
I have the internal mod successfully running vct on hks cams
if your vacuum has decreased then perhap more air is needed to bypass the throttle through the idle air control...have you played with that at all?
Yeah had a play with it. Didn't check to see if it increased vacuum but will when I go at it again. That's probably why it isn't working how it suppose to be. Use to be able to control idle perfectly with power fc. Guess I will mess with it again until I am able to control with the power fc again.
Really? Ok how is your restrictor setup in the block? How does your car drive with it unplugged? Is there a noticeable difference with it on or off?
Mines doesnt work cause I did the idle test by activating it while car idling and there was no idle change and also I have it unplugged now and driveabilty is the same. No change at all.
Edited by Daboss
someone here will have the answer, but these are my thoughts and i'm still really learning so i could be wrong but advancing the exhaust cam timing will decrease overlap and increase cylinder pressure...which would lead to more heat being generated.
Edited by Badgaz
Vct is 1.5mm Middle blocked and rear 1.4mm. Idle is poor with the vct turned on and with it off the midrange is about 40kw less
Vct is 1.5mm Middle blocked and rear 1.4mm. Idle is poor with the vct turned on and with it off the midrange is about 40kw less.
Same specs with my build. Only thing is i havent been on a dyno to check power output as yet. Most definitely there is no idle change when vct activated at idle and it feels the same driving wise whether plug is on or off.
Other than the idle check i have noway of telling if it is actually always on, cause driveablity remains the same but that could be the effect of it always being on and idle is poor after cam install. Vacuum at idle is in the -10's rising the more rpm I make without getting into boost.
Checked and rechecked timing, added and subtracted both fuel and ignition timing, opened and closed idle air control valve, adjusted tps sensor and advanced exhaust cam gear 6 degrees.
Everything is within spec just idle is not as smooth as i would like it to be car vibrates and engine shakes to much. It is not horrid just a little off and its bugging the hell out of me.
The cam gear advance seemed to help a bit but didn't want to go any further than that as it seemed to far advance at 6.
So I am back to it either being vct or cams, also i have a very small gap on my spark plugs,
its odd that you cant adjust the revs lower than 1000rpms, what gap are the plugs? are they getting wet cause once there wet it will never idle smooth.
Plugs are gapped very tightly. I am thinking they are .5mm. Have not checked the plugs for wetness. I reinitialized the power fc and did the idle learn again, Rpm is steady at 950/1000 according to hand controller and I have it set at 900. That is with the idle air screw opened all the way. Didnt try to adjust with hand controller as it was kinda idling within spec.
Feel that controlling the idle is within my grasp as it is now idling steadily between 950 and 1000 and i have a few adjustments I can make to get it as close to perfect as I can.
What injectors?
650cc about to be changed to 850cc top feed denso.
Problem seems to be solved. CAS was broken. Car now idles as before with a slight miss but no violent shaking. I have noticed that my water temperature gets noticeably higher than what I am use to. Use to seeing about 95c to 98c staying there under normal conditions and boosting with fans running as soon as hood opened with fans on temps would drop down to low 80'sand thermo fans would cutoff. Temps would build back up fans cut back on and so on and so on.
Now the temp gets to 102c and stays there even with hood open, fans on and after a hard run.
Can advancing the exhaust cam gear raise water temps? I ask because while trying to fix idle problem I had advance the exhaust cam 6 degrees and have not placed it back to normal.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
