If it's not eccentric/offset, i can't see that it would matter...is this for r33gtst?
There might be void spaces (or blobs of different material) inside it to adjust its firmness in the up-down vs fore-aft directions. Perhaps unlikely with a caster bush, but possible.
I'm just about to replace my stock HCR32 ones with Nismos, I can't get underneath to take a photo, a mate has borrowed my ramps, but it appears the stock ones have the arrow pointing towards the front of the car.
Thanks for he help mate, I googled the nismo caster arms complete and I can see the arrow pointing towards what would be the front of the car not back towards the arm.
For anyone else interested these bushes fit all r and s chassis cars and some others like Cefiro stagea etc.
The 52mm wide Nismo bushes are made for the Nismo radius rods. Almost certain they wont fit in stock rods. Maybe Nismo make a bush for the stock rods too? OP measure the width of the metal sleeve, if its <52mm you should be ok.
Edit: Doh 2WD is different.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
