Skid Pan Day At Slidewise Gympie - 18-04-15
Event:
Skid pan day in Gympie
Description:
Since we have some interest, time for another one. A great opportunity to get your car on a skid pan and have a heap of fun sliding around while also learning about car control. A BBQ lunch will also be provided.
Slidewize Gympie
Date:
Saturday the 18th of April.
Time:
Drivers briefing starts at 8:00 sharp, all drivers must be present at the beginning ot the briefing or their spot is forfeited.
Lunch will be at 12-12:30
The day will finish around 3:30
Cost:
$140
This get you and ONE passenger/co-driver and lunch for both of you.
Requirements:
  1. Open licence (sorry, Slidewize are not covered for P platers in their insurance)
  2. CTP rally extension for the event, call up your CTP insurer and enquire about getting this for the day. Proof of this extension MUST be brought to the day.
  3. Full exhausts on the car
  4. Helmets are not required but we strongly advise you to bring one if you can
  5. Completed indemnity form (attached)
Payment Details:
Name: Skylines Australia Queensland Club
Bank: Westpac
BSB: 034 063
ACC: 354012
PAYMENT REFERENCE: Skidpan&username
Attendees:
  1. Cadmoon
  2. Shannon Jansen
  3. sneaky pete PAID
SlideWize-Indemnity (1).pdf
Fire Plan (1).pdf
Tips & Hints (1).pdf
Paid. I need to remember to get myself the CTP rally extension.
Here's the general spiel that Aaron sends off to people that was emailed to me through someone at work yesterday:
"Throughout the skid pan day I run a variety of fast paced, educational and challenging activities that make for an action packed and fun filled day.
The morning session is spent sliding around several different tracks marked out on the skid pan. Drivers go out on the skidpan in pairs for 4 min sessions.
This is a great time for drivers to get a 'feel' for the car. It allows drivers to test how much grip the vehicle possesses
and to explore the limits of the driver in a safe and controlled environment.
Below are a few clips to give you an idea of how it works.
http://www.youtube.com/watch?v=iILQbCa2nW8
http://www.youtube.com/watch?v=FCTanvgGvm8
I supply a BBQ lunch and soft drinks which is included in the price for driver and co-pilot.
After lunch we do the following driving games:
Go-to-whoa: Great way to test the raw power and braking of a vehicle!
A pair of cars line up, one on either side of the bitumen track. A whistle is sounded and the race is ON!
http://www.youtube.com/watch?v=c6vIXDDk6GU
Shoot out: 2 cars line up on the skid pan to complete a tight little circuit. This really tests both the driver and vehicle.
Again, whistle is sounded, and watch the machines flex their muscles.
http://www.youtube.com/watch?v=68oByBWCqPM
Time Trial:
I utilize the entire bitumen circuit for the time trial. A short track is created, and the stop watch is pulled out.
Drivers take their turn to run the time trial and see what they can do.
This trial adds a little speed, tight cornering, braking and requires a smooth driver!
Time trial normally takes about 1min per driver. If time is available, the trial will be run twice!
http://www.youtube.com/watch?v=-kvNey5T5BU
Details:
All participating drivers require an open drivers license.
All cars entering on the day will need a CTP extension. This is not difficult to obtain but must be obtained from your insurer at least 24 hours before the event, Monday-Friday, during business hours. This covers death to any person in the event of a fatal accident. Any vehicle or property damage is NOT covered by me or my insurance.
Payments:
Attached is the payment info. When you make a payment, please use your name and skid date in the reference section.
Eg: "David Brown 11/10/13"
Attached is the usual paperwork.
CTP Extension: Needs to be gained during business hours.
Ring your insurance provider for your vehicle registration. CTP has NOTHING to do with car insurance.
Suncorp & AAMI are free, RACQ is $10
On the day, I will need a copy of your CTP extension, and a copy of your printed out and filled in Indemnity form.
Thanks
Aaron"
CTP is part of your rego Ralph. If you have rego you have CTP, check your renewal/certificate to find out who is your current insurer and give them a call a couple of days before the event.
easy fixed,help out with everything around the house,make her feel really speacial and then when you want to go to skid pad,she will be happy to let you go since youve been such a good and helpful partner.sign,sealed,delivered. :)
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
