  • Replies 345
jnr_j,
To me it sounds like a dodgy contact on the starter or in the starter. More than likely it'll be a bad contact on the main starter leads, or in the solinoid itself.
I would suggest that you take the starter off, pull it to bits (I've done this to mine and it's easy), give it all a good clean and put it back together.
Took me about an hour to do all this.
Mine was over running (not disengaging when the motor had started), and cleaning it fixed it up perfectly :)
J
When i turn the key and nothing happens i can hear a click. Its not very loud but i guess it's the solenoid, sounds close to the dash. So maybe the problem is with the circuit feeding the starter power rather than the solenoid open/close circuit. When i turn the key the dash lights remain on but the clock display and acc power fade out. Is this the norm?
The "experts" seemed to think it must be a connection somewhere rather than the starter itself being screwed, just because when it finally goes it has no trouble, but didn't make much progress looking into it because they couldn't see it happen.
I might try Jay's suggestion of pulling the thing out. Here's hoping that makes a difference.
John
jnr_j - that click you hear might be coming from the solinoid. Get someone to stick their head under the bonnet next time it's doing it. If the starter is clicking but not starting the car, then that's your problem. It's a common problem in heaps of cars.
J
Originally posted by Obseshn
If there's someon on here with a white R33 with no rear wing, chopped springs, and lives in Gordon area, or was visiting that area Friday night...your a moron, i'm sorry, but really, you give a bad name to Skyline drivers. Tailgating, overtaking down and inside on an emergency breakdown lane, and just generally driving like an idiot.
Okay, i'm done now.
heh...saw a wingless white R33 in Mitchell, lowered...HAD to be the same guy :( He hammered it down the road, went tru the red light at the end, and had the car sideways up the hill...
Yeah, probably the same one :(
Why are there so many people who think public roads are their race track? There's a time and a place for driving your car hard, and a public road is not it.
Hopefully he/she calms down before they do some major harm to themselves, someone else, the car, or property.
Anyway, on a brighter note, i'm slowly working things out with my car. But, i've heard alot lately about 33's not able to be complianced yet? I don't know what the go is there, might fire Prestige an email and get him to fill me in.
Just got to talk to the bank, and offload my car. I think my mum/sister want to keep it...so that's cool, at least i know it'll be safe and i can see it still :(
Yeah, probably the same one :D
Just got to talk to the bank, and offload my car. I think my mum/sister want to keep it...so that's cool, at least i know it'll be safe and i can see it still :)
Joe from Skyline Performance was telling me that they were going to be able to start importing again about a month after the SEVS came in. He also mainly deals with R33's, so u might be in luck Obseshn:D
there are a couple of RAWS workshops listed on the gov site...both in QLD though...but I'm sure it won't be long before more are up and running.
but the point is, as long as there at least one, you'll be ok :P
I got my car complianced in QLD.
Have you guys seen the Red R32 GTR (With Black Bonnet & Gold Wheels) ???
That Thing looks insane...! (Wonder what sort of power it is putting out)
As Earlier mentioned my car is for sale - Anybody interested? - I might bring it out to a cruise... (Trying to keep K's down for sale)
www.geocities.com/r33forsale
Actually, Goran is only a member of Shogun and they cruz with us Elite guyz occasionally. His friend Luch has a similar powered TT Supra - both R outstanding! On a similar note...does anyone know the other burgundy R32 GTR going around with a few stickers and a big alloy t-wing?
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
