RB Light Weight Flywheels $375
Guest darrinspencer
If we can get 10 people together i can get light weight flywheels to suit all RB motors Rb20, Rb25, Rb26 Rb30 for $375 each
They weigh 6.5kg each
They come complete with a new ring gear.
Made from high carbon 4340 steel.
Flywheels are CNC machined locally in Brisbane.
Previous group buys were $495 and made from a lower grade 4140 steel.
So that makes these great value.
Normal price for these flywheels are $450
Delivery to other states approx $20.
Confirmed people wanting one
Darrin PAIDED
Myr332 PAIDED
Sciby
Shane
Rb20-calais
Jaws
Bullant47 PAIDED
UPDATE
Flywheels are ready
We have 7 people
3-5 more available.
Please scroll thru to post no. 47 for payment details
__________________
https://www.sau.com.au/forums/topic/45331-rb-light-weight-flywheels-375/
  • Replies 66
how long u looking at doing this? even at 450 thats cheap. I'm interested if its in a month or two. I just put bilsteins in and my pockets are incredibly shallow at the moment and the credit card debt seems to be increasing lol.
4340 is perhaps the highest grade high tensile steel that most machine shops can machine!!! THe japanese ones that are below 5 kgs are a totally different kettle of fish they are billet cast then machined (very expensive)... Also all you guys wanting to go below 5 kg have you thought of the effect on MAIN bearingS when doing this and not haveing the crank balanced; as you would in a rebuild.... Word of warning!! Going to light would be detramentle...
free bump!!!they sound good pity i have a tripple plate!!
Put me down for an RB25 lightweight flywheel. I am based in Sydney so I would have to organise delivery, but if that's good then yep definitely right to go!!!
Normal price for these wheels are $450
Pictures will be added some time tommorrow.
__________________
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
